Photon energy of a certain material?
The discussion revolves around a problem involving photon energy absorption and emission in a certain material at varying temperatures. The material absorbs photons of specific energies (0.37 eV and 0.64 eV) when kept at low temperatures and emits photons when warmed up. Participants are exploring the implications of energy levels and transitions in this context.
  • Participants discuss the relationship between photon energies and energy levels, questioning how to relate the absorbed and emitted photon energies to quantum states. Some suggest using the formula for energy levels, while others consider the implications of temperature on these states.
The discussion is active, with participants raising various interpretations of the energy levels and transitions. Some have proposed potential approaches, while others have pointed out inconsistencies in reasoning regarding the energy differences and the implications of temperature on the energy states.
There is an ongoing debate about the assumptions regarding energy levels and the nature of transitions between them, particularly in the context of low temperatures and the conditions for photon absorption and emission. Participants are also considering the constraints imposed by the problem statement regarding the range of photon energies.
physicslove22
A certain material is kept at very low temperature. It is observed that when photons with energies between 0.23 eV and 0.85 eV strike the material, only photons of 0.37 eV and 0.64 eV are absorbed. Next the material is warmed up so that it starts to emit photons. When it has been warmed up enough that 0.64 eV photons begin to be emitted along with 0.37 eV photons, what additional photon energy is observed to be emitted by the material?
-13.6/N^2 = Energy in eV
I'm completely stuck :(
Unfortunately, "I'm completely stuck" doesn't qualify as an attempt at a solution. You have to try something and show us what you tried.
Would I be on the right track if I set -13.6/N^2 equal to .37, and then solve for N? Then I could use trial and error to find a multiple of N that is between .23 and .85?
N= 6.06, so never mind on the previous post...
So I know that photons can only be absorbed at the energy amounts from where they are to N=1, so is this problem saying that N=2 is .37 and N=3 is .64?
What is N? And what is 13.6?
"Energy in eV" in post 1 is the energy of the states, not the energy of photons that get emitted or absorbed.
Oh... Also I just realized that -13.6/N^2 is only for hydrogen atoms, I will need to devise a different approach...
A photon can be absorbed by a system (atom or molecule if the difference between the energy levels of the system is equal to the energy of the photon.
When the material is at very law temperature, it is at the deepest energy level. You can call it level 1 . The photon can rise it to the next level, or to the third one, and so on, according to the photon energy. If you count the energy of the levels from the first level, you can say that the energy of the second level is 0.37 eV and that of the third level is 0.64 eV.
What about photon emission at high temperatures?
Would it emit photons from N=3 to N=2, N=2 to N=1, and N=3 to N=1? So it would be .64 and .37eV?
No, this won't work, because that would make the difference between the second and third levels 0.64 - 0.37 = 0.27 eV, so there would have been absorption observed of 0.27 eV photons; but the conditions of the problem exclude that. So the 0.64 eV must be the difference between the second and the third levels. (Or it could be the first and second, and 0.37 eV could be the difference between the second and third; that is actually more likely, given the usual distribution of energy levels in atoms, but we don't actually need to know which is right to solve the problem in the OP.)
Yes.
Those are two of the three transitions you listed. (Key question: which two?) The key is to figure out the third.
We don't have to know which number the different states have.
Not if the second level was empty at zero temperature.I think we have to make the additional assumption that there are no forbidden transitions, otherwise we can construct systems we cannot solve.
Even if it starts out empty, it won't be empty once some 0.37 eV photons have been absorbed.
It's not a matter of forbidden transitions; it's a matter of which arrangement of energy levels is consistent with the entire statement of the problem. Given only the two photon energies absorbed, there are two possible arrangements; only the extra information in the problem statement (about the range of photon energies that were used to irradiate the object) allows you to rule out one of those two possibilities and get a unique solution.
I don't think we are supposed to take this second-order effect into account.
Forbidden transitions increase the number of possible arrangements of energy levels.
I don't see how the two possible arrangements lead to different predictions, with and without taking second-order effects into account. I get two different arrangements but the same answer for both.
If we don't, I don't see how we can solve the problem. (Feel free to PM me to discuss further, since we should be giving the OP a chance to find the solution for himself.)
The only possibility I can see from this is that one of them would be 1.11, which doesn't fit the limits the problem gave us...
I think you mean 1.01, i.e., 0.64 + 0.37, correct?
The limits in the problem were on the range of photon energies used to test for absorptions of photons. There is no reason why emissions of photons could only take place within that range of energies. The energies of photons used to irradiate the material are under the experimenter's control, so the experimenter can decide to only test for absorption of photons in some particular range of energies. But the energies of photons emitted by the material when it is heated are not under the experimenter's control; there is no way for the experimenter to restrict emissions to a particular range of energies.
Oh! That makes a lot more sense now! Thanks for all your help!
Very low temperature means that only the ground level is occupied, all atoms/molecule are on that level. The absorbed photon can excite the system onto the second or third level. Usually the intensity of the light is not enough to excite many atoms/molecules, and the lifetime of an excited state is not long, so you can take that almost all particles of the material are in the ground state at low temperature. So there probability that the photon rises the system from the second level to the third one is very low.
At high enough temperatures the thermal energy of the particles is enough to excite an other particle from the first level to the second one. The number of the excited particles becomes so much that you observe the radiation when the excited particles return to their ground state. Warming further, the number of particles excited to the third level becomes so high that you observe the radiation accompanying transition from the third level to the first one. At high temperatures, there is an appreciate amount of particles excited both to the second and the third level. If the transition 3-->2 is allowed, you will observe it, and the photon emitted during this transition has the difference of the energies.
Of course, there is some probability that particles are excited to higher levels at high temperature, and then photons are emitted when transition occurs between any two levels. But the text says that the material is warmed up to the temperature, when 0.64 eV photons begin to be emitted. It means that the ratio of particles excited to higher levels is very low, so the number of photons produced from transitions involving higher levels are too few to be observed.
9K
13K
