Photon excitation to full orbitals
9 replies · 2K views
ngc2024
In introductory physics and chemistry, photon excitation is usually illstrated with a simple hydrogen molecule. I am wondering what happens if an electron is excited to an orbital that is already full. Would the orbital split up into different energy levels as hybridisation, so as not to violate the pauli exlusion principle?
So that means that a photon with energy corresponding to the energy difference between, say n=1 and n=2, would not be absorbed if n=3 is filled?
These numbers are not quite correct. But say that you have F- in the electronic configuration 1s22s22p6: even if you have photons of energy E2p-E1s, there will be no absorption, while you would have absorption for neutral fluorine.
Chandra Prayaga said:
The phenomenon is called Spectral Hole Burning.
Just to be clear: while spectral hole burning is a manifestation of what we are discussing, it applies only to cases where there is initially absorption. In the example I mentioned, the orbitals were already filled.
It has to do with Pauli's exclusion principle. No two electrons can occupy the same quantum state. So you cannot excite an electron to a filled orbital.
Note: Pauli's exclusion principle does not apply only to electrons but to an entire class of particles- fermions.
Yes. All that has happened in your case is that you are half way through the process.
Not to be offtopic, but isn't this more of a general chemistry related question? This is exactly what I learned in my chemistry class.
