Photosynthetically active radiation transmission
When building an algae scrubber for a reef tank, the choice of material for a light shield significantly impacts the percentage of Photosynthetically Active Radiation (PAR) transmitted to the algae. Regular glass, low iron glass, and 1/8" acrylic are common options, but their effectiveness varies in light transmission. Light intensity decreases quickly with distance, making it crucial to position the lights as close as possible to the algae while managing salt spray. PAR primarily encompasses wavelengths between 420 and 650 nanometers, which are optimal for algae photosynthesis. Researching the specific light transmission properties of these materials can help determine the best choice for maximizing PAR.
salty joe
I am building an algae scrubber for a reef tank and am trying to decide what material transmitts the largest percentage of PAR. My choices are to place the lights an inch or so from the algae with a clear shield, or move the lights at least 12" away to avoid salt spray/creep. I don't know a lot of physics, but I know that light intensity drops off in a hurry with distance. So I want to get the lights close. I can't afford exotic materials, so I guess my choices for the shield are regular glass, low iron glass and acrylic probably 1/8" thick.
Can anybody point me to a link or in a direction to determine what material will transmitt the highest percentage of PAR?
Thanks,
Joe
Science news on Phys.org
What is 'PAR', exactly (e.g., the wavelength range)?
Table 3.1 in Photosynthesis (sixth edition, Hall and Rao, page 40) shows that all the various algae pigments (green, red, brown) have photosynthesis absorption maxima between about 420 and 650 nanometers (blue and red light).
Bob S
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
