Physical Chemistry- Partial Pressures
3 replies · 5K views · last reply
PerenialQuest
Hello all,
This is a homework problem for my CHE345 class. Not sure what to do here, please at least let me know if I'm in the right ballpark.
A student decomposes KCLO3 and collects 35.2 cm^3 of O2 over water at 23.0°C. The laboratory barometer reads 751 Torr. The vapor pressure of water at 23.0°C is 21.1 Torr. Find the volume the oxygen would occupy at 0.0*C and 1.2atm (= 912 Torr).
not exactly sure what is relevant here. Perhaps these:
(1) PV = nRT
(2) Pj = partial pressure
(3) xj = mole fraction
(4) Pj = xjP
(5) Pj = njRT/V
(6) Ptotal = PA + PB +...
My problem I think, is in interpreting the question, but here goes an attempt:
using eq. (6):
Ptotal = Pwater + PO2
751 Torr = 21.1 Torr + PO2
PO2 = 729.9
from here I'll use eq. (1) to solve for nO2
PV = nRT
n = PV/RT
n = (729.9 Torr)(0.0352 L)/(62.634 L Torr K-1mol-1)(296.15 K)
n = 1.385 x 10-4
Now to solve for the V at Tfinal
V = nRT/P
V = (1.385E-4 moles)(62.634 L Torr K-1mol-1)(273.15 K) / 912 Torr)
V = 0.002598 L = 2.598cm3
How'd I do?
PerenialQuest said:
Hello all,
(1) PV = nRT
(4) Pj = xjP
(5) Pj = njRT/V
using eq. (6):
PO2 = 729.9
PV = nRT
n = PV/RT
n = 1.385 x 10-4
V = nRT/P
How'd I do?
You made an arithmetic error in calculating the number of moles. The pressures and temperatures in the two situations are not too different, and, if the volume was much less than 35.2 cc, this should have alerted you that there was an arithmetic mistake somewhere. Try to get used to asking yourself whether your answer makes sense.
1. Homework Statement
2. Homework Equations
(1) PV = nRT
(4) Pj = xjP
(5) Pj = njRT/V
3. The Attempt at a Solution
using eq. (6):
PO2 = 729.9
PV = nRT
n = PV/RT
n = 1.385 x 10-3
V = nRT/P
V = (1.385E-3 moles)(62.634 L Torr K-1mol-1)(273.15 K) / 912 Torr)
V = 0.02598 L = 25.98cm3
Ah yes, thank you, I missed a digit. That better? Did I go about the problem correctly?
