Physical interpretation of Feynman path integral
In summary: Feynman.In summary, the physical interpretation of Feynman path integral is still open to many possibilities.
  • #36
Feynman said:
So gentelman ,
we are taking about the Path which mean (maybe) manifolds, and not complex .
My question is why the path can be consider that is a manifold and can be consider the path integral is an integral over a manifold?
Thanks
I can't make head or tail of this. Clarify please?
  • #37
Feynman said:
So gentelman ,
Thanks
String theory uses a type of path integral, only it sums up 2D "paths", on 1D paths. There they do say that the Feynman path integral is "summed over manifolds". I suppose the same thing can be said of the 1D case.
  • #38
So do you have some idea about contruction of this path integral?
thanks
  • #39
Which path integral ?For each physical system u have a path integral that gives u the amplitude of probability of transition from one quantum state to another...
:confused:
  • #40
  • #41
All path integrals are Feynman path integrals. He invented 'em.
  • #42
so?
what do you mean selfAdjoint
  • #43
so?
  • #44
He means "equal to his Adjoint". :tongue2: :rofl:
  • #45
Feynman said:
so?
*You were asked, "Which path integral?" meaning for which observable.
*You replied Feynman path integral.
*I pointed out that all the path integrals under discussion are Feynman path integrals, as a gentle hint to look at what the question meant. Sigh...
  • #46
If we are really going to discuss path integrals, let me write some down so we can discuss what the variables are:
(These equations were taken out of Hatfield's book)
[tex]
\psi (x,t)\,\, = \,\, G(x,t;xo,to)\,\, = \,\,\int D \hat x(\hat t) \,\, {\rm exp(}i{\rm }\int_{t_o }^t {L[\dot {\hat x},\hat x,\hat t]d\hat t} ) \,\, = \,\,\,\int D \hat x(\hat t) \,\, {\rm exp(}i{\rm }\, S[\hat x(\hat t)])
[/tex]
My question is what is [tex]\psi (x,t)[/tex]? Isn't this just the normal wave function solved for with the regular Schrodinger equation? Where does h or h-bar go in these equations?
[tex]
\Psi [\phi (\vec x,t)]\,\, = \,\, G[\phi ,t;\phi o,to]\,\, = \,\,\int D \hat \phi \,\,{\rm exp(}i{\rm }\int_{t_o }^t {d\hat t\int {d^3 x} \,\,L[\dot {\hat \phi} ,\hat \phi ,\hat t]} )\,\, = \,\,\,\int D \hat \phi \,\, {\rm exp(}i{\rm }\,\, S[\hat \phi (\hat t)])
[/tex]
What is [tex]\Psi [\phi (\vec x,t)][/tex] called?
Is it possible to do a 3rd quantization? What would that be? Would that be the field of all possible fields? Would this be the field from which any kind of particle field would emerge?
[tex]
\psi (x,t)\,\, = \,\,\,\int D \hat x(\hat t) \,\,{\rm exp(}i\,\int\limits_{to}^t {d\hat t\,S_o [\hat x,\hat t]} \, - \,\lambda V(\hat x))\,\, = \,\,\sum\limits_{n = 0}^\infty {{{( - i\lambda )^n } \over {n!}}\,\,\int D \hat x(\hat t) \,\,{\,\,\,(\int\limits_{to}^t {dt'\,\,{\rm V}[x(t)])^n }\, \,\,\,{\rm exp(}i\,\,\int\limits_{to}^t {d\hat t\,S_o [\hat x,\hat t]} } )\,\,}
[/tex]
Is this correct, or should it be the time integral over the lagrangian minus the potential times lambda? Is it true that lambda is the charge giving rise to the potential V? Or is it the charge subject to the potential V?
Are there symmetries involved with So that make it easy to solve for? Does the addition of lambda time V always a form of symmetry breaking process? Does this mean that any time there is a symmetry breaking process that there will be a lambda that is a quantized value? Does this mean any time there is a quantized value there is a process of symmetry breaking responsible for it? Is quantization equal to symmetry breaking?
Thanks.
PS: It took me an hour and a half to construct the equations and write this post.
  • #47
I took this from Hatfield's book, Quantum Field Theory Of Point Particles and Strings, page 307, eq 13.12.
[tex]
\Psi [\phi (\vec x,t)]\,\, = \,\, G[\phi ,t;\phi_o,t_o]\,\, = \,\,\int D \hat \phi \,\,{\rm exp(}i{\rm }\int_{t_o }^t {d\hat t\int {d^3 x} \,\,L[\dot {\hat \phi} ,\hat \phi ,\hat t]} )\,\, = \,\,\,\int D \hat \phi \,\, {\rm exp(}i{\rm }\,\, S[\hat \phi (\hat t)])
[/tex]
My question is what is [tex]\Psi (x,t)[/tex] called? Are there alternative names for this? How is it described? How does it differ from [tex]\phi (x,t)[/tex]? Where does h or h-bar go in these equations? Are there "limits" to the integration over [tex]D \hat \phi [/tex] ? Or would this be considered some type of indefinate integral requiring some sort of initial conditions to determine a constant of integration?
Thanks.
  • #48
Thank you Mike2, [tex]\Psi (x,t)[/tex] is the solution of SCHROD equation's,
But the problem is HOW WE CA DEFINE [tex]D \hat \phi [/tex]? mathematically and physically
thx
  • #49
  • #50
But the problem is HOW WE CAN DEFINE [tex]D \hat \phi [/tex]? mathematically and physically
thx
As I recall, [tex]\phi (x,t)[/tex] is the wave function of 1st quantization. And I believe [tex]\Psi (x,t)[/tex] is called the "field" of second quantization. Are there any other names for [tex]\Psi (x,t)[/tex], for example, amplitude of something, field of something? Thanks.
The integration over [tex]D \hat \phi [/tex] is over all of "functional space", over all possible changes in the function [tex]\phi (x,t)[/tex] that gets you from the starting [tex]\phi_i (x,t)[/tex] to the ending [tex]\phi_f (x,t)[/tex]. It would appear that there is no geometry involved with this space, right? I mean, there would have to be a metric associated with this functional space in order to have geometry, right?
  • #51
But integration over a sheme or path (i think) is a deduction from homotopy theory and algebic topology?
  • #52
? Integration derives from measure theory. There is a link to homotopy, but I don't think homotopy is prior.
  • #53
Just a moment... There is an "inner product" defined on these spaces, aren't there? This inner product determines amplitudes, right? So would this inner product define a metric for this space? What is this space called, Hilbert space, Fock space, ...? Thanks
  • #54
But Mr selfAdjoint I have an article which talk about the importance of the homotopy to construct the Feynman path integral
  • #55
But Mr Mike2 How we can define this measure?
And i think that the differential and algebric geometry has an important role on construction of these measure
  • #56
Citation please? Link if possible?
  • #57
ok Mr selfAdjoint But this article is on french!
  • #58
That's irrelevant.Please make a link to the article...
  • #59
ok dextercioby , but i don't know how i send this article.
  • #60
If the article is online, go to it, copy the URL (in the address box at the top of your screen), then come here and paste the url into the reply window. PF doesn't even need all the link apparatus, it automatically puts url tags before and after every url it recognizes.
  • #61
This is the article
  • #62
so?please help me
  • #63
Who can i browse this article ?
  • #64
What article? Did you have a link?
  • #65
Finnally this is the adrres of the article:
lpt1.u-strasbg.fr/kenoufi/MEMOIRES/magistere.pdf
  • #66
so no answer?
  • #67
http://lpt1.u-strasbg.fr/kenoufi/MEMOIRES/magistere.pdf
The paper discusses the path-integral in so-called "multiple connected"
spaces, as opposed to "single connected" spaces. The homotopy aspect
here is not important to understand the principle of the path integral.
Elementary introduction to grasp the ideas:
"QED, the strange theory of light and matter from Feynman"
Feynman deriving Schrödingers equation from the Path-integral:
"Space-time approach to non-relativistic Quantum Mechanics"
(Rev.Mod Phys. 20, 367-387 (1948)
Which you can find reprinted here in "Feynman's Thesis"
This brand new book which was published just last month is edited by
Laurie M. Brown who wrote a breakthrough paper together with Feynman
in 1952 (!) "Radiative Corrections to Compton Scattering"
The important follow-up papers from Feynman are:
"The theory of positrons (1949)" , start of the relativistic path integral.
Followed by:
"Space-time approach to Quantum Electro Dynamics, (1949)"
All the above papers can be found in the collection:
"Selected Papers of Richard Feynman"
(Again with Laurie M. Brown as editor)Regards, Hans
  • #68
Feynman said:
Hi
What is the physical interpretation of Feynman path integral?
Thanks :smile:
Here's a little one-page summary of the FPI that I wrote after studying the Feynman and Hibbs text for a while. Go to the files section of my yahoo group and download the file: FPI.pdf.
http://groups.yahoo.com/group/QM_from_GR/files/
:biggrin:
David
  • #69
For Hans de Vries , so wath is the physical difference between the multiple connected and single connected and where the path integral entered in this case?:grumpy:
  • #70
You can find the meaning of "simply connected" and "multiply connected"
in any textbook on complex analysis. Simply connected means that you
can deform each possible path between two points into any other.
Otherwise they are multiply connected
However, This is hardly relevant for studying the path-integral in a four
dimensional world. Maybe you should ask the author here:
http://dcwww.camp.dtu.dk/~kenoufi
Since the paper is his first years master's thesis.
(When he talks about multiply connected paths, he means paths in 3D space)
Regards, Hans
Feynman said:
:grumpy:...
Grumpy?
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
