Physical interpretation of Feynman path integral
88 replies · 23K views
selfAdjoint said:
Mike means that a path (a one-dimensional continuum) is a manifold. A one-dimensional manifold. But I am sure that wasn't what you meant. But I can't figure out what you did mean.
I've taken to re-reading about path integrals to see if I can get a better intuition of what's going on. Hatfield's presentation seems to be the best I've seen so far - not so many things pulled out of the hat.
In (my) words, it is the integral over all possible paths of the exponential of "i" time the action. The "e" to the "i" of something is always less than or equal to one. This is the weight given to each path in the sum? So I wonder, what values can the Action take? Can it be anything from zero to infinity? Can it be negative? Thanks.
Mike, e to the power i times something is always a complex number of modulus (i.e. magnitude) 1. THe "something", a function of time, shows the angle the number makes with the real axis. As Feynman says in QED, think of a "little arrow" of length 1 that can point anywhere in a 360o circle, like a dial or a compass needle. As the particle travels, the vector representing the exponential rotates around at a steady rate (because the exponent of e was a linear function of time). So at every point on the path it is pointing somewhere or other, and all the paths are like that they all have little arrow pointing at some angle in the plane. It's better to think of each path having a dial somewhere outside of the spacetime picture where the pointer can go around. This is all really metaphor for complex numbers.
So then you add up (integrate) all the complex values along each path and then integrate the sums across all the paths, and what happens is that all the different pointing arrows wash each other out and only the classical path comes out of the integration.
So each "path" is weighted by the same magnitude but different phase?
I'm sure there is a little more to then that. The path integral does not result in a classical path; for then there would be no need for path integral in the first place. I think it means that the classical path simply contributes most to the path integral than for the far fetched paths, right?
First question, yes if it's just the [tex]e^{i\psi t}[/tex], but you can have multipliers of the whole exponential that change the modulus. The key is Euler's relation: [tex]me^{i\theta} = mcos\theta + imsin\theta[/tex].
Second question, no, there is AFAIK no reason prior to Feynmann's method that quantum amplitudes should give the classical (stationary action) path.
So gentelman ,
we are taking about the Path which mean (maybe) manifolds, and not complex .
My question is why the path can be consider that is a manifold and can be consider the path integral is an integral over a manifold?
Thanks
Feynman said:
So gentelman ,
Thanks
I can't make head or tail of this. Clarify please?
Feynman said:
So gentelman ,
Thanks
String theory uses a type of path integral, only it sums up 2D "paths", on 1D paths. There they do say that the Feynman path integral is "summed over manifolds". I suppose the same thing can be said of the 1D case.
So do you have some idea about contruction of this path integral?
thanks
All path integrals are Feynman path integrals. He invented 'em.
so?
what do you mean selfAdjoint
so?
Feynman said:
so?
*You were asked, "Which path integral?" meaning for which observable.
*You replied Feynman path integral.
*I pointed out that all the path integrals under discussion are Feynman path integrals, as a gentle hint to look at what the question meant. Sigh...
If we are really going to discuss path integrals, let me write some down so we can discuss what the variables are:
(These equations were taken out of Hatfield's book)
[tex] \psi (x,t)\,\, = \,\, G(x,t;xo,to)\,\, = \,\,\int D \hat x(\hat t) \,\, {\rm exp(}i{\rm }\int_{t_o }^t {L[\dot {\hat x},\hat x,\hat t]d\hat t} ) \,\, = \,\,\,\int D \hat x(\hat t) \,\, {\rm exp(}i{\rm }\, S[\hat x(\hat t)])[/tex]
My question is what is [tex]\psi (x,t)[/tex]? Isn't this just the normal wave function solved for with the regular Schrödinger equation? Where does h or h-bar go in these equations?
[tex] \Psi [\phi (\vec x,t)]\,\, = \,\, G[\phi ,t;\phi o,to]\,\, = \,\,\int D \hat \phi \,\,{\rm exp(}i{\rm }\int_{t_o }^t {d\hat t\int {d^3 x} \,\,L[\dot {\hat \phi} ,\hat \phi ,\hat t]} )\,\, = \,\,\,\int D \hat \phi \,\, {\rm exp(}i{\rm }\,\, S[\hat \phi (\hat t)])[/tex]
What is [tex]\Psi [\phi (\vec x,t)][/tex] called?
Is it possible to do a 3rd quantization? What would that be? Would that be the field of all possible fields? Would this be the field from which any kind of particle field would emerge?
[tex] \psi (x,t)\,\, = \,\,\,\int D \hat x(\hat t) \,\,{\rm exp(}i\,\int\limits_{to}^t {d\hat t\,S_o [\hat x,\hat t]} \, - \,\lambda V(\hat x))\,\, = \,\,\sum\limits_{n = 0}^\infty {{{( - i\lambda )^n } \over {n!}}\,\,\int D \hat x(\hat t) \,\,{\,\,\,(\int\limits_{to}^t {dt'\,\,{\rm V}[x(t)])^n }\, \,\,\,{\rm exp(}i\,\,\int\limits_{to}^t {d\hat t\,S_o [\hat x,\hat t]} } )\,\,}[/tex]
Is this correct, or should it be the time integral over the lagrangian minus the potential times lambda? Is it true that lambda is the charge giving rise to the potential V? Or is it the charge subject to the potential V?
Are there symmetries involved with So that make it easy to solve for? Does the addition of lambda time V always a form of symmetry breaking process? Does this mean that any time there is a symmetry breaking process that there will be a lambda that is a quantized value? Does this mean any time there is a quantized value there is a process of symmetry breaking responsible for it? Is quantization equal to symmetry breaking?
Thanks.
PS: It took me an hour and a half to construct the equations and write this post.
I took this from Hatfield's book, Quantum Field Theory Of Point Particles and Strings, page 307, eq 13.12.
[tex] \Psi [\phi (\vec x,t)]\,\, = \,\, G[\phi ,t;\phi_o,t_o]\,\, = \,\,\int D \hat \phi \,\,{\rm exp(}i{\rm }\int_{t_o }^t {d\hat t\int {d^3 x} \,\,L[\dot {\hat \phi} ,\hat \phi ,\hat t]} )\,\, = \,\,\,\int D \hat \phi \,\, {\rm exp(}i{\rm }\,\, S[\hat \phi (\hat t)])[/tex]
My question is what is [tex]\Psi (x,t)[/tex] called? Are there alternative names for this? How is it described? How does it differ from [tex]\phi (x,t)[/tex]? Where does h or h-bar go in these equations? Are there "limits" to the integration over [tex]D \hat \phi[/tex] ? Or would this be considered some type of indefinate integral requiring some sort of initial conditions to determine a constant of integration?
Thanks.
Thank you Mike2, [tex]\Psi (x,t)[/tex] is the solution of SCHROD equation's,
But the problem is HOW WE CA DEFINE [tex]D \hat \phi[/tex]? mathematically and physically
thx
But the problem is HOW WE CAN DEFINE [tex]D \hat \phi[/tex]? mathematically and physically
thx
As I recall, [tex]\phi (x,t)[/tex] is the wave function of 1st quantization. And I believe [tex]\Psi (x,t)[/tex] is called the "field" of second quantization. Are there any other names for [tex]\Psi (x,t)[/tex], for example, amplitude of something, field of something? Thanks.
The integration over [tex]D \hat \phi[/tex] is over all of "functional space", over all possible changes in the function [tex]\phi (x,t)[/tex] that gets you from the starting [tex]\phi_i (x,t)[/tex] to the ending [tex]\phi_f (x,t)[/tex]. It would appear that there is no geometry involved with this space, right? I mean, there would have to be a metric associated with this functional space in order to have geometry, right?
But integration over a sheme or path (i think) is a deduction from homotopy theory and algebic topology?
? Integration derives from measure theory. There is a link to homotopy, but I don't think homotopy is prior.
Just a moment... There is an "inner product" defined on these spaces, aren't there? This inner product determines amplitudes, right? So would this inner product define a metric for this space? What is this space called, Hilbert space, Fock space, ...? Thanks
But Mr selfAdjoint I have an article which talk about the importance of the homotopy to construct the Feynman path integral
But Mr Mike2 How we can define this measure?
And i think that the differential and algebric geometry has an important role on construction of these measure
Citation please? Link if possible?
ok Mr selfAdjoint But this article is on french!
ok dextercioby , but i don't know how i send this article.
If the article is online, go to it, copy the URL (in the address box at the top of your screen), then come here and paste the url into the reply window. PF doesn't even need all the link apparatus, it automatically puts url tags before and after every url it recognizes.
