Physics: 1d Motion-Instantaneous Velocity vs Average.
This discussion focuses on the calculation of instantaneous velocity from average velocity in one-dimensional motion. The method involves using the average velocity at time t1 and adjusting it with the midpoint of the averaging periods. Specifically, the instantaneous velocity can be approximated by taking the average of the average velocities at the center of each interval. For example, between t1 = 0.05 seconds and t2 = 0.10 seconds, the instantaneous velocity is calculated as 32.5 cm/s by averaging the velocities of 30 cm/s and 35 cm/s.
  • Understanding of basic kinematics principles
  • Familiarity with average and instantaneous velocity concepts
  • Ability to interpret and manipulate data tables
  • Knowledge of mathematical modeling techniques
  • Research methods for fitting data to model functions in physics
  • Learn about numerical differentiation techniques for calculating instantaneous velocity
  • Explore the implications of data sampling on velocity calculations
  • Study the relationship between average and instantaneous velocity in different motion scenarios
Students studying physics, educators teaching kinematics, and anyone interested in understanding motion analysis and data interpretation in physics.
Gaebril
Trying to create a table with time and instantaneous velocity. (the tables- http://i.imgur.com/8DZsu.png ) How do I go from using the Average Velocity to the Instantaneous Velocity?
Instantaneous Velocity is the V_avg at t_1 + (delta-t)/2 how do I use this with my data.
You have to make some assumptions about the smoothness of the data, because you lose some information from only having sampled data. See if you can fit the data to a particular model function. If you can't, then you can just estimate the instantaneous velocity = the average velocity at the center of each averaging period. The centers of your averaging periods are between each sample point. If you want the instantaneous velocity at your sample points, then you can take the midpoint between each pair of average velocities. Of course, it's all very approximate.
So between t1=.05 and t2=.10 you take the mid point of the average velocities which is 30 + 35 = 65/2 = 32.5cm/s? Thus at t2 instantaneous velocity = 32.5cm/s?
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 60 ·
