Physics Egg Car Project Tips: How to Safely Transport an Egg from a 1m Ramp
To successfully transport an egg from a 1m ramp using gravitational potential energy, consider using Styrofoam for egg protection and adding weight to increase speed. A vehicle design with three wheels—two at the back and one at the front—can help maintain balance during the fall. Experimentation is key; building and refining the design will enhance the learning experience. Recording the experiment can provide valuable insights for improvement. Researching existing projects can also offer inspiration and guidance for effective egg protection strategies.
Snow_11
I have to create a vehicle to safely transport an egg from a ramp 1 m above the floor. The car must be powered solely with gravitational potential energy, must fall and land of its wheels, and I get a better grade for the farther away it lands from the ramp... but I'm completely lost of how to construct this vehicle.
I was thinking of doing something with Styrofoam, to protect the egg, and maybe put a weight somewhere to make it go faster down the ramp to land farther away from the ramp, and use 3 big wheels (two in back and one in front) to balance it out when it falls... but even with this, I still have absolutely no idea how to construct it.
Any tips on how to build this successfully would be much appreciated!
Make it and try it then refine your approach. This would be a lot more fun. Think of all the eggs you get to break.
I would also suggest video recording the experiment so you can view it frame by frame.
You should be able to find many examples online of how other students have protected egos during a drop.
Maybe you could make a glider to carry the egg.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
25K
10K
10K
