Physics Homework Help: 3-Part Problem with Mass, Friction, and Spring Forces
The problem involves a 9 kg mass sliding on a surface with friction, interacting with a spring. The mass's initial speed is 4 m/s, and the coefficient of friction is 0.34. The task is to analyze the motion of the mass as it compresses the spring and subsequently moves in the opposite direction.
  • Participants discuss the energy transformations involved, including kinetic energy and work done against friction. There is mention of setting up equations to relate initial and final energies, as well as the need to show work for clarity.
Some participants are attempting to guide the original poster by suggesting an approach based on energy conservation principles. There is acknowledgment of the original poster's struggle with the material, and a call for them to engage more actively in the problem-solving process.
The original poster expresses significant difficulty with the subject matter and personal circumstances that may be affecting their ability to focus on the homework. There is an emphasis on the requirement to show work for assistance.
stacerho
I am having trouble understanding how to work this 3 part problem.
A 9 kg mass slides to the right on a surface having a coefficient of friction 0.34. The mass has a speed of 4 m/s when contact is made with a spring that has a spring constant 159 N/m. the mass comes to rest after the spring has been compressed a distance d. The mass is then forced toward the left by the spring and continues to move in that direction beyond the outstretched position. Finally the mass comes to rest a distance D to the left of the unstretched spring. The acceleration of gravity is 9.8 m/s^2.
Part 1) Find the compressed distance d. Answer in units of m
Part 2) Find the speed vfinal at the spring’s unstretched position when the mass is moving to the left. Answer in units of m/s
Part 3) Find the distance D where the mass comes to rest. Answer in units of m.
In order to get help you MUST show your work!
I don't have a clue, I've been so lost in this class from the beginning. I cannot even figure out where to start and that's the problem. I just need to pass this class. I'm having a baby in a few weeks and just have had so much trouble grasping this stuff.
Under the circumstances, I'll try and show you how to approach this, but you must make some effort yourself.
This one of those energy and work problems with a before and after state.
At the beginning the energy in the system is the KE of the mass. There's a simple formula for that. After the block stops moving the first time, the energy it used to have has gone into frictional loss and the spring.
If the block moved distance d before stopping, the work ( energy) lost to friction is mgdc where c is the coefficient of friction. The energy in the spring is Kd^2 where K is the spring constant.
If you equate the initial and final energies you get a quadratic equation in d which is a piece of cake to solve.
I am very confused about a question about sound waves. I am confused about the given. If the given is not in the question then how do you figure it out.
Yes that's the problem thank you
  • · Replies 58 ·
