Physics of Glove side movements in Baseball Pitching
  • Context: Graduate
  • Thread starter Thread starter mcloven
    Baseball Physics
The discussion centers on the physics of glove side movements in baseball pitching, specifically relating to the conservation of angular momentum. Participants analyze how a pitcher's glove arm can influence the acceleration of the throwing arm by adjusting its position in relation to the rotational plane. Key concepts include the relationship between tangential velocity and rotational velocity, with references to geometric approximations for body parts and their rotational inertia. The conversation emphasizes the importance of considering both forward momentum and the vertical orientation of the rotational planes in this analysis.
  • Understanding of conservation of angular momentum
  • Basic knowledge of rotational dynamics
  • Familiarity with tangential velocity concepts
  • Ability to apply geometric approximations in physics
  • Research the principles of angular momentum in sports physics
  • Study the effects of body mechanics on pitching techniques
  • Explore the mathematical modeling of rotational inertia
  • Investigate the role of momentum transfer in athletic performance
Baseball coaches, sports scientists, biomechanics researchers, and athletes looking to enhance pitching performance through an understanding of physics principles.
mcloven
I had a question that I think relates to conservation of angular momentum.
What are the physics behind a pitcher using his glove side in these gifs? Could it help accelerate his arm by pulling his glove side shoulder/arm in (or out of the rotational plane)? I guess also need to take into account converting forward momentum in addition to the rotational.
Like this skater using her arm to jump?
I think you called it,
his ball arm extends to increase its tangential velocity on release
and his glove arm comes into increase his rotational velocity (because of conservation of angular momentum)
you could kind of approximate by ignoring the height difference between hands and assigning some geometric shapes with known rotational inertia ot particles as parts of body and glove and ball, interesting problem If it wasn't my last chapter but this one I would quantify everything to the best of my ability for ya, but yes your getting the concept
EDIT; re-looking at pics, ignoring any difference in height wouldn't work cause the rotational planes pretty vertical, but some approximations would still totally make this problem doable with a good degree of accuracy. The forward movement would qualify as cm of system movement and could just be added to the tangential velocity upon release (but he doesn't release tangent to the circle its more of an arch so that might throw off some numbers)
EDIT 2 : maybe it is roughly tangent to a circle with his cm at the center, that would make sense, I'd have to know more about baseball or decide on some reasonable approximations based on optimizing tangential velocity to help you further
  • · Replies 23 ·
