[Physiology] Intuition behind the Nerst equation
The discussion revolves around the intuition behind the Nernst equation, particularly focusing on how the charge of an ion affects the voltage calculated from the equation. Participants explore the relationship between ion charge, concentration gradients, and the resulting voltage across a membrane, with an emphasis on understanding the underlying principles rather than deriving definitive conclusions.
  • One participant seeks to understand why voltage decreases as the charge of the ion increases, suggesting that a higher charge would lead to greater electrical force and thus greater voltage.
  • Another participant points out a potential misinterpretation of the Nernst equation, clarifying that "mV" is a unit and does not change with the charge of the ion.
  • A participant explains that voltage is proportional to the difference in charge across the membrane and describes the balance between electric force and concentration gradient affecting ion movement.
  • One participant reiterates their confusion, stating that a higher charge should lead to lower voltage output in the context of the Nernst equation, using specific voltage examples to illustrate their point.
  • Another participant responds by explaining that voltage represents energy per unit charge, indicating that if an ion has a higher charge, the voltage must be adjusted accordingly.
Participants express differing views on the relationship between ion charge and voltage, with some agreeing on the technical aspects of the Nernst equation while others remain uncertain about the implications of charge on voltage. The discussion does not reach a consensus on the intuition behind the equation.
Participants highlight potential misunderstandings regarding the interpretation of units in the Nernst equation and the physical principles governing voltage and charge interactions. There are unresolved aspects related to the intuitive understanding of these concepts.
Hammad Shahid
TL;DR
Why does the mV decrease as the valence increases?
The equation:
V(x) = 61*mV*(1/z)*(log[X(o)/X(i)])
Where:
z = valence (charge of ion)
[X(o)] = reference concentration (outside the cell)
[X(i)] = concentration of species inside the cell
I want to understand the intuition behind why the mV decrease as the charge increases. From what I understand, as a higher charged ion species moves across the membrane, the electrical force will be increased by a greater amount for each permeant. This will lead to equilibrium being reached before too many ions are displaced.
From there, I do not get how it will lead to a greater voltage (charge separation). While yes, less ions need to be moved in order to counter the chemical (concentration) force, at the same time they carry a higher magnitude charge, so doesn't that balance out?
Maybe I don't understand how voltage works exactly. I haven't taken physics so I do not know for sure how voltage and currents work.
Thanks.
Biology news on Phys.org
Do you mean the Nernst Equation? Your description seems a bit confusing.
@jim mcnamara I’m pretty sure it’s a misinterpretation of the Nernst equation:
$$E_{cell}=E^{\ominus}-\frac{RT}{zF}\ln\frac{[\text{Red}]}{[\text{Ox}]}$$
At STP, and converting natural log to base ten log (edit: and assuming ##E^{\ominus}=0## and flipping the fraction in the logarithm), we get
$$E_{cell}=\frac{61\text{mV}}{z}\log_{10}\frac{[\text{Ox}]}{[\text{Red}]}$$
@Hammad Shahid In this case, “mV” is a unit (millivolts), not a variable. It’s not going to change with ##z##.
Voltage is proportional to the difference in charge between the two sides of the membrane.
Suppose we have a membrane that is permeable to X+ only. Initially, there is X+A- on one side of the membrane, and Y+B- on the other side. The X+ will move across the membrane from a region of high X+ concentration to region of low X+ concentration, leave A- behind, so one side of the membrane will become increasingly negatively charged relative to the other side. As more X+ moves across the membrane, the A- side becomes more negative, and will try to pull the X+ back. So the electric force will try to keep the X+ with the A-, while the concentration difference will try to drive the X+ to the other side of the membrane. The X+ will stop moving down its concentration gradient when the the opposing tendencies due to the electric force and concentration gradient match each other.
I think I wasn't clear in the question. I meant that having a higher charge will lower the answer in end. Since the answer is in mV, if let's sat having a +1 charge gives -50 mV as the answer, a +2 charge will give -25 mV.
I didn't understand why having a higher charge in a species would lead to a lower charge separation.
Because volts are joules per coulomb. In other words, the voltage In your equation represents the energy per unit charge to move an ion. If an ion has two units of charge, the voltage must be halved if the same amount of energy is expended.
Thanks. That makes sense. This is exactly what I was looking for.
  • · Replies 16 ·
9K
17K
