MHB Do Pi and Geometric Shapes Coexist?
The discussion centers on the presence of the mathematical constant $\pi$ in various geometric shapes, specifically ellipses and polygons. It is established that $\pi$ is integral to the area of an ellipse, expressed as $\pi ab$, while the circumference is described by complex elliptic integrals. In contrast, polygons like squares do not inherently contain $\pi$ unless their angles are considered, as angles are defined in relation to circles. The conversation highlights that $\pi appears in geometry primarily when angles are involved, and its relevance extends to physics, particularly in formulas involving full rotations.
  • Understanding of geometric shapes, particularly ellipses and polygons.
  • Familiarity with the mathematical constant $\pi$ and its applications.
  • Knowledge of angles and their relationship to circles in geometry.
  • Basic concepts of elliptic integrals and their significance in geometry.
  • Explore the properties of elliptic integrals and their applications in calculating the circumference of ellipses.
  • Study the relationship between angles and circles to understand the role of $\pi$ in polygons.
  • Investigate the concept of projective geometry and its implications for conic sections.
  • Learn about the use of $\tau$ in simplifying physics formulas that involve full rotations.
Mathematicians, geometry enthusiasts, physics students, and anyone interested in the mathematical properties of shapes and their applications in real-world scenarios.
highmath
(1) Is there a pi in ellipse entity?Why not or yes?
(2) Is there a pi in polygons entities (e.g square)? not or yes?
(3) If there is pi in some geometries and other not - What is the reason to that?
(4) How cloud I know that are no hidden formula of pi in a square figure that the expression in formula, his value is: 0 in addition and 1 in multiplicatoin and etc
Mathematics news on Phys.org
I really don't understand what you mean by this. "$\pi$" is a number. What do you mean by a number "in" in a geometric figure? If you mean formulas for circumference, area, etc. Then it is true that the area of an ellipse, with semi-axes of lengths a and b is $\pi ab$, very similar to the formula for the area of a circle. On the other hand, while the circumference of a circle is simply $2\pi r$, there is no simple formula for the area of an ellipse.
I'll add a note here:
The Greeks, at least, defined [math]\pi[/math] as the circumference of a circle divided by its diameter. So [math]\pi[/math] does come up in a lot of geometric figures. But if you are trying to find some deeper reasoning to it you aren't going to find it. It's just a handy definition.
-Dan
We can roughly divide geometry in angles and coordinates.
We see $\pi$ in the domain of the angles and not in the domain of the coordinates.
In a simple right angle on the unit circle we have the simplest possible coordinates with $0$ and $1$.
Its angle is $\smash{\frac \pi 2}$.
Its hypotenuse is $\sqrt 2$, which is an algebraic number and not transcendental like $\pi$.
So $\pi$ comes along whenever an angle or turn is involved.
To find the area of a circle, we integrate over the angle so that we see $\pi$ back in the result.
An ellipse is a circle scaled in one direction by a factor, which scales its area by the same factor.
So yes, there is $\pi$ in the area of an ellipse.
The circumference of an ellipse is so complicated that an elliptic integral function was invented to describe it.
Still, there is probably a $\pi$ hidden in there somewhere.
The coordinates of a polygon and its sides are typically algebraic numbers.
Its angles contain $\pi$, but $\pi$ only shows up if we map the polygon into the domain of a circle, since that is how angles have been defined. If we would identify angles by their coordinate ratios (slopes) there would be no $\pi$.
Through projective geometry a circle is transformed, or rather is equivalent to an ellipse, a parabola, and a hyperbola. These are the so called conic sections.
We already saw $\pi$ in the area of an ellipse.
A parabola and a hyperbola don't have an area though as they are unbounded. If we bound a parabola with a line at an algebraic coordinate, we don't see $\pi$, but we see an algebraic number. A hyperbola bounded by a line gives an area that contains $e$ instead of $\pi$.
The arc length of a parabola also contains $e$, while the arc length of a hyperbola is too complicated to tell.
We see $\pi$ a lot in physics formulas as well, and usually as $2\pi$ or $4\pi^2$. What these formulas have in common is that they deal with a full turn. As we know, the arc length of a full turn is $2\pi r$. All those physics formulas would be simplified if we used $\tau$ for a full turn instead of $2\pi$.
  • · Replies 29 ·
  • · Replies 17 ·
