What is the energy of photons in pion decay at rest?
The energy of photons produced during pion decay at rest can be calculated using the equation E^2 = p^2 c^2 + m^2 c^4, which simplifies to E = mc^2 when the pion is at rest. The momentum of the pion is zero, leading to the conclusion that its energy is solely derived from its mass. Conservation of energy dictates that the total energy of the pion equals the sum of the energies of the two photons produced, expressed as E(pion) = E(photon1) + E(photon2). The rest mass of the photon is zero, and its energy can be calculated using E = pc.
  • Understanding of relativistic energy equations, specifically E^2 = p^2 c^2 + m^2 c^4
  • Familiarity with the concept of conservation of energy in particle physics
  • Knowledge of the properties of photons, including their rest mass being zero
  • Basic understanding of momentum and its relationship to energy in relativistic contexts
  • Study the derivation and implications of the equation E^2 = p^2 c^2 + m^2 c^4
  • Learn about the conservation of momentum in particle decay processes
  • Explore the concept of gamma (γ) in relativistic physics and its calculation
  • Investigate the relationship between mass-energy equivalence and photon energy in detail
Students and researchers in particle physics, physicists interested in relativistic mechanics, and anyone studying the properties of subatomic particles and their decay processes.
rwooduk
Apologies, this is going to be a bit disjointed, I don't want to write the full question down as I don't want anyone to give me a solution as its an assignment question.
1. am i correct in assuming when a pion decays at rest its energy will be given by:
which goes to:
E^2 = m^2 c^4
because I get something ridiculous like 1394J. I've canceled the c^2 of the pion mass with the c^4 in the energy eqn.
2. to find the energy of the photons i use conservation of energy:
E(photon1) = GAMMA * m c^2
i) what do i use for the mass of a photon?
ii) how do i calculate gamma when no velocity of the photons (or the pion) is given?
thanks in advance for any suggestions.
The photon has a rest mass of zero, so the energy equation reduces to:
E^2 = p^2 c^2, or E = pc.
The equation E = gamma m c^2 applies only for a massive particle.
So take the equation E = pc, then conserve energy and momentum to calculate the energy of the two photons.
thanks for the reply!
but using conservation of energy E(pion) = E(photon1) + E(photon2) doesn't seem to help because although we now have E(pion) the energies of each photon may not be equal. also how would you calculate momentum without a velocity?
thanks again.
btw the question says to assume relativistic, so I am back to the problem of how to find gamma with no velocities given.
What is the momentum of the initial pion at rest? What does this tell you about the momentum of the final system?
Also on your question about momentum, for the photon E = pc. What is p?
i) the momentum of the pion is zero at rest, so it's energy would be zero, so you would have to assume that it had a momentum before it came to rest and that it is the dissipation of this momentum that is 'given' to the photons?
how else could it impart energy if it had none at the point of decay?
unless it has an intrinsic energy inherent to the particle itself, would that be in the form of mass?
so E = GAMMA * mc^2
so the momentum of the final system would be only the energy its mass imparts
so E= GAMMA * mc^2 = pc
but again I am stuck with GAMMA when i have no given velocities.
OK, think I am there,
E(pion) = GAMMA * mc^2
COE:
E(photon) = 1/2 E(pion)
p(photon) = E(photon) / c
Only thing is how to find GAMMA with no velocities given? should i just write the answer in terms of GAMMA?
I see that K = (GAMMA - 1) mc^2 is the kinetic energy, can you assume this is equal to its rest mass, hence find GAMMA this way, or does it have to be moving for this to be true?
Thanks for the direction!
No. The pion has a mass m. E^2 = p^2c^2 + m^2c^4. If p = 0, then E = mc^2.
Also, as you wrote, E = gamma mc^2. If p=0, v=0, so gamma = 1, giving again E = mc^2.
So the initial momentum is zero, but not the initial energy.
You are given the initial velocity. It says at rest.
ahhh i see and you can calculate the momentum of the photon from COE because we know the energy of the pion.
thanks for all the pointers, really appreciated!
11K
