Pipeline structural Support loading case from riser pipeline.
  • Thread starter Thread starter Jonathanjc
    Structural Support
The discussion focuses on designing a structural support for a pipeline connected to a riser at a 60-degree angle. Key considerations include the loads transferred from the riser, which involve both perpendicular and axial forces (Fb and Fa). The participant emphasizes the importance of accounting for the reaction forces due to vertical loads (Fy) and the effects of gravity on the weight of the pipe and fluid. The consensus is that both axial forces and moments must be included in the load calculations for accurate support design.
  • Understanding of structural analysis principles
  • Familiarity with Free Body Diagrams (FBD)
  • Knowledge of load transfer mechanisms in pipeline systems
  • Experience with axial and perpendicular load calculations
  • Research methods for calculating axial forces in pipeline supports
  • Learn about the impact of gravity on fluid-filled pipelines
  • Explore advanced structural analysis techniques for inclined supports
  • Study the effects of moment forces on structural integrity
Structural engineers, pipeline designers, and anyone involved in the analysis and design of pipeline support systems.
Jonathanjc
Hi all,
I am trying to designing a structural pipeline support. The pipeline is at a 60 degree angle and is connected to a riser pipeline - I have the transferred loads that the pipeline will experience from the riser and have created an FBD.
I initially thought the load that the support would carry would be perpendicular to the pipeline Fb (see diagram) but I also think there would be Fa to consider also. I am also under the assumption that the moment would not add to the supported load.
Can anyone offer advice about the best way in finding the loads that the support will have to carry. As I am unsure whether I am on the right track.
Thanks in advance
J
edit: Yes. You have to consider the reaction due to your Fy. The weight of the pipe and fluid due to gravity, and also the axial forces due to bends, connections, etc.
thanks!
