- #36
- 3,447
- 1,236
So, I see what you did, but I don't really understand why you did it. It seems you found a force acting on a cross section, then converted that into some kind of work, (while neglecting any mention of the fluid having to travel up through the inclined portion, during which work would be done), and called that work done by gravity. However, I don't really see how you can can this work done by gravity. All the work you calculated was perpendicular to the direction of gravity.
You've basically calculated the work done by pressure, except that there would be no work done by pressure because in this example, you are assuming the fluid isn't moving. If the fluid was moving, you'd need to include the effects of acceleration on the local pressure.
So what is it you are actually trying to prove or show here? I am not entirely certain what your goal is. It doesn't seem to relate to your original question about a Pitot tube. With that question, the answer is relatively easy: the flow stagnates against the tip of the probe, so it reaches stagnation pressure, there is a hole that transmits that pressure into the tube, and then the hydrostatic pressure from the column of liquid in the tube has to exactly equal the stagnation pressure at the tip in order for the force balance to work.
