What are the factors that contribute to crevice corrosion in stainless steel?
  • Thread starter Thread starter jra12222
    Corrosion
This discussion centers on the factors contributing to crevice corrosion in stainless steel, particularly in aqueous environments. Key elements include the necessity for crevices to be sufficiently large to allow corrosive agents entry while remaining stagnant, as well as the role of trapped pollutants and moisture in excluding oxygen. The formation of an oxide layer between the metal and oxygen is crucial, as it inhibits electron flow, and this layer can be compromised through mechanical actions. Additionally, two critical factors for crevice corrosion are identified: a drop in potential within the crevice and the specific chemical composition of the electrolyte.
  • Understanding of electrochemistry principles
  • Familiarity with corrosion mechanisms, specifically pitting and crevice corrosion
  • Knowledge of stainless steel properties and behavior in aqueous solutions
  • Basic mechanical engineering concepts related to materials science
  • Research the electrochemical processes involved in crevice corrosion
  • Study the impact of different electrolyte compositions on corrosion rates
  • Explore methods for preventing crevice corrosion in stainless steel applications
  • Learn about the mechanical factors that can compromise protective oxide layers
Mechanical engineers, materials scientists, and corrosion specialists seeking to deepen their understanding of crevice corrosion mechanisms and prevention strategies in stainless steel applications.
jra12222
Hi all,
I am trying to understand how the process of either crevice or pitting corrosion works (I believe they are quite the same)
I understood the part of how they start and what enhances them or how they can be prevented, but I can't understand an actual scenario.
Say for example we have stainless steel in a water solution;
  1. From which elements and to which elements do the electrons travel?
  2. With which elements does the water react? -> and does it always change to hydrogen and hydroxide?
  3. How does hydrogen increase the acidity?
  4. Why does the steel where the corrosion take place always become the anode?
I would really appreciate it if someone could explain this to me!
Thanks a lot!
I am actually in my final year of the degree (mechanical engineering) however materials was never my strong point :sorry:
I did read that information before and I also watched a number of videos on pitting/crevice corrosion, however I couldn't find a suitable example explanation.
A summary of what I know (will focus on Crevice):
  • the fact that the crevice needs to be big enough for the corrodent to enter but small enough to remain stagnant,
  • the fact that crevices trap pollutants, moisture, and excludes oxygen (not entirely sure about the oxygen however to be honest, since it is required for corrosion to take place)
  • the oxide layer formed between the metal and oxygen to stop electron flow
  • this layer can be broken by mechanical means like scratching
  • and in order for crevice corrosion to take place 2 factors are important:
    1. drop in potential into the crevice
    2. and the chemical composition of electrolyte
As you can see what I know (assuming it is correct) is only the theoretical aspect, I don't know how it would actually happen.
  • · Replies 17 ·
