Placing charges with coulomb's law problem
11 replies · 17K views · last reply
kirby2
Problem: a charge +Q is located at the origin and a second charge, +4Q is at a distance d on the x-axis. where should a third charge, q, be placed, and what should be its sign and magnitude, so that all three charges will be in equilibrium.
attempt:
I don't know how to solve it fully, but my initial thought is to put the third charge in between the other two and give it a negative sign. The two other charges repel each other so i thought a negative one in the middle would put them in equilibrium. is this right?
attempt:
You are right about the sign of the third charge.
Considering, for a moment, only the positive charges:
1. Is there any location along the x-axis where the electric field is zero?
2. What is the magnitude of the force that the two positive charges exert on each other?​
Answering those should give you a good start.
am i correct by saying that there is no point on the x-axis where the electric field is zero
No.
For any location between x = 0 and x = d, The direction of the electric field due to the +Q charge is in the opposite direction of the electric field due to the +4Q charge . Therefore, there is some location between x = 0 and x = d at which the electric field due to those two charges is zero. At that location, what is true of the magnitude of the field due to +Q compared to the magnitude of the field due to +4Q ?
In my experience, by the time you encounter a problem like the one in this thread, you would have already done some problems with two charges located on the x-axis and you are to find the location at which the electric field is zero.
i think i got it. it should be placed right d/3 from origin. sign negative. and charge of 7.11 x 10^(-20).
That's the correct location.
You haven't given a specific value for the charge Q. How can you give a specific numerical value for the 3rd charge, q ?
Use the second hint I gave you.
kirby2 said:
i assumed Q to be 1.6 x 10^(-19)
Any reason for that assumption?
If you assume that, then the third charge, q, will be a fraction af one electron charge.
the force that the two charges exert on each other is (k)((4Q^2)/d^2). but i don't know how that helps
That is a force of repulsion.
The middle charge, q, must exert a force equal to that. As you have concluded previously, charge, q, must have a sign opposite to that of Q & 4Q, so that it attracts both of them.
What is the (magnitude of the) force exerted on each other by the charge, Q, at the origin and the charge, q, at x = d/3 ?
Set that force equal to [itex]\displaystyle \frac{4k\,Q^2}{d^2}\,.[/itex]
kirby2 said:
OK. i think its -3Q.
Magnitude of the force between Q & 4Q:
[itex]\displaystyle \frac{4k\,Q^2}{d^2}\,.[/itex]​
Magnitude of the force between Q & q: assuming q is at x=d/3 and q = -3Q:
[itex]\displaystyle \frac{4k\,(3Q)\cdot Q}{(d/3)^2}=27\frac{4k\,(Q^2)}{d^2}\,.[/itex]​
