Mentor
- 51,045
- 27,083
keji8341 said:Taking light as a wave, the Doppler effect of wave period actually describes the relation between the time interval in which one moving observer emits two δ-light signals and the time interval in which the lab observer receives the two δ-signals at the same place. The period should be a measurable physical quantity. The lab observer cannot know the period before he receives the second δ-light signal.
Taking light as consisting of photons, a single photon has the information of frequency. But when using a single photon to derive Doppler formula, the photon's momentum and energy is supposed to form a momentum-energy 4-vector, which exactly corresponds to a plane wave, and the Doppler formula (namely Einstein's plane-wave formula) is only applicable to a plane wave.
True. See below.
keji8341 said:How about to fire two photons, one left-approaching overlap-point and one right-approaching overlap point? The lab observer received two photons at the same time, which have different frequencies! You got "discontinuity".
So what? It's two different photons, with two different (k, w/c) 4-vectors. There's no discontinuity in either one individually.
In fact, you're not even picking the toughest example. Let's go back to your first proposed model above, where light is a wave, and in order to measure its frequency I need a wave train of finite length, over a finite interval of time. Suppose that finite interval of time includes the instant at which the moving source passes the stationary observer? It would seem in that case that we *would* indeed have the discontinuity in a single wave train!
However, even here the discontinuity is an illusion. What is actually happening is this: the moving source is emitting *two* wave trains, one we'll call A (for "approaching") in the positive x-direction (the same direction as its motion), and one we'll call R (for "receding") in the negative x-direction. Suppose the moving source passes the stationary observer at the instant t = 0, and suppose we look at the time interval -T to T in order to measure the frequency of the light. What the observer will see is that, at time t = 0, he abruptly stops receiving wave train A and starts receiving wave train R. If he includes both wave trains in a single measurement, then yes, it will look like there's a discontinuity in frequency, but that's because he's mixing together measurements from two separate wave trains. If instead he does the measurement right, measuring wave train A from -T to 0, and wave train R from 0 to T, then he will correctly conclude that wave train A's frequency is blueshifted and wave train R's frequency is redshifted, and there is no discontinuity in either wave train. The only discontinuity is that he stops receiving one wave train and starts receiving another at t = 0, but that has nothing to do with the Lorentz invariance of any 4-vectors involved.
