Mentor
- 37,196
- 16,297
See the contour plot I posted above, sorry about editing at the same time you were editing.
DaleSpam said:See the contour plot I posted above, sorry about editing at the same time you were editing.
DaleSpam said:First, you have provided no sound justification for this.
It does. I simply plotted the formula I posted above. I can post my code.keji8341 said:But I don't think your imposed Lorentz transformation creates such a picture.
It is. I can post the details later today when I return.keji8341 said:Your Lorentz transformation is not a standard Lorentz transformation.
DaleSpam said:It does. I simply plotted the formula I posted above. I can post my code.
DaleSpam said:It is. I can post the details later today when I return.
I did not do that. I told you exactly the conditions I used:keji8341 said:I guess you plotted the contours under the condition w't'-|k'||x'|=0 or ct'=|x'|. If so, that's the problem.
You are calling me a liar? Here is my code, you can check for yourself that it is as I say.keji8341 said:But I don't think your imposed Lorentz transformation creates such a picture.
Yes it is.keji8341 said:Your Lorentz transformation is not a standard Lorentz transformation.
I don't know what would lead you to believe this. The Lorentz transformations will not decouple two dependent quantities. In the frame where the point source is at rest k' depends on r', so I don't know why you would think that the Lorentz transform would decopule them in the moving frame so that k would be independent of r. Your understanding of the Lorentz transform seems to be incorrect.keji8341 said:In standard Lorentz transformations, (k,w/c) and (x,ct) are completely independent.
DaleSpam said:keji8341, your understanding of the wave four-vector, the Lorentz transform, and relativistic Doppler shift seems to be fundamentally flawed. Unfortunately, I don't know where your basic misunderstanding lies, so I cannot be more helpful.
The derivation that I posted shows how the wave four-vector formalism is applicable to spherical waves, how the wave vector transforms correctly, how the resulting frequency reduces to the standard relativistic Doppler shift formula, and how the resulting phase shows the familiar pattern of non-concentric sphers propagating outward at c. Furthermore, there is expermiental validation of this behavior, in particular the seminal experiment by Stilwell and Ives and subsequent similar experiments.
The wave four-vector is a legitimate four-vector, is therefore mathematically self-consistent and compatible with current physical theory, as well as being experimentally validated. You have no basis to object to its use in justifying the invariance of Planck's constant.
DaleSpam said:Attached is my code, completely open for inspection.I did not do that. I told you exactly the conditions I used:
"Here is a contour plot of the lines of constant phase for t=1, z=0, and v=-.6."
There is no problem. The plot is correct and accurately reflects the familiar behavior of Doppler-shifted spherical wavefronts. This familiar behavior emerges naturally from the formalism of four-vectors and how they transform.
Yes it is.
[tex]\left(<br /> \begin{array}{cccc}<br /> \frac{1}{\sqrt{1-\frac{v^2}{c^2}}} & -\frac{v}{c \sqrt{1-\frac{v^2}{c^2}}} & 0 & 0 \\<br /> -\frac{v}{c \sqrt{1-\frac{v^2}{c^2}}} & \frac{1}{\sqrt{1-\frac{v^2}{c^2}}} & 0 & 0 \\<br /> 0 & 0 & 1 & 0 \\<br /> 0 & 0 & 0 & 1<br /> \end{array}<br /> \right)[/tex]
Compare to http://en.wikipedia.org/wiki/Lorentz_transformation#Matrix_form
It is completely standard.
Classical point particles themselves are also not physical at all, and many other valid formulas suffer the same problem. So I see no issue here.keji8341 said:1. My main question is: your Doppler formula has a sigularity at the overlap-point (you realize that), which is not physical at all.
It reduces to his in the appropriate situation.keji8341 said:2. Your Doppler formula is different from Einstein's formula.
No, it doesn't. Different photons go to different locations. No photon changes frequency.keji8341 said:3. From your Doppler formula, the observed frequency in the lab frame changes with locations, as you indicated in your post #73:
"Off of the x-axis the Doppler shift depends on both position and time..."
That means a photon's frequency changes during propagation
Many physics equations express a dependence between vectors in two different spaces. The fact that they are in different spaces has nothing to do with whether or not two vectors are independent. In this case the dependency between x and k is given by the equation [tex]\phi=g_{\mu\nu}x^{\mu}k^{\nu}[/tex]keji8341 said:The wave 4-vector (k',w'/c) in the source-rest frame and (x',ct') are completely independent originally, belonging to two different spaces.
Then kindly point out in my code exactly where my code deviates from a standard Lorentz transform.keji8341 said:I realized that your Lorentz transformation is not a "standard" Lorentz transformation. Let me explain.
DaleSpam said:No, it doesn't. Different photons go to different locations. No photon changes frequency.
DaleSpam said:Then kindly point out in my code exactly where my code deviates from a standard Lorentz transform.
I assert that it is standard and as evidence I have posted the formula I used, a link to the standard formula for comparison, and my code. You are either saying I am a liar and deliberately misrepresenting my code or you are saying I am stupid and don't realize I am misrepresenting it.
So either point out the exact line in my code where I deviate from the standard Lorentz transform or stop impugning my integrity.
Again, it is not my model, it is the standard Lorentz transform, but I appreciate and accept the apology, provided you don't return to accusing me of falsifying the Lorentz transform.keji8341 said:I completely believe your calculations based on your own math model. ... If any of my words make you unhappy, that is never my original intention, and I apologize to you.
No, k is a four-vector, so the transformation matrix is the Lorentz matrix. That is essentially the definition of a vector, that it transforms according to the Lorentz matrix.Phrak said:The transformation matrix to obtain (k_x',w') from (k_x,w) should directly derive from the Lorentz matrix transforming (x,t) to (x',t'), where k_x = 1/x and w = 1/t.
DaleSpam said:No, k is a four-vector, so the transformation matrix is the Lorentz matrix. That is essentially the definition of a vector, that it transforms according to the Lorentz matrix.
The error was that you needed to derive a different transformation matrix. You simply use the standard Lorentz transformation matrix.Phrak said:"No, k is a four vector", or "yes, k is a four vector?" There's nothing in error in what I said that I can see.
Yes, I demonstrated it for the case of a spherical source.Phrak said:Have you demonstrated that it transforms as a four vector or given a reference? This is a very long thread.
DaleSpam said:The error was that you needed to derive a different transformation matrix. You simply use the standard Lorentz transformation matrix.
DaleSpam said:Post 74, with the code posted in 97. If you have Mathematica then I would start with 97 since it is more complete.
DaleSpam said:No, that is not correct. That would mean that the wavelength increases as the wave gets further from the source. Why would you think that?
This means you can't use dimensional analysis on any equations derived from this assumption. To avoid confusion you would have to reinsert symbols for [itex]\omega[/itex] and c into the formulae.DaleSpam said:...I will use units of time such that in the primed frame w=1 and units of distance such that c=1.
Yes, as you suggest here x/r is correct, not x/r² as you suggested above. My formula for k is correct.Phrak said:A wave front at r, centered at the origin, has wave numbers kxi = xi/r.
I am using the standard convention. Phase is dimensionless, x has units of distance, and k therefore has units of inverse distance. As DrGreg points out I am using units of time such that w=1 and units of distance such that c=1. So you need to plug the appropriate factors back in wherever the units don't make sense. I apologize for the confusion that has caused. It is a pretty common thing to do, but it is somewhat sloppy and definitely confusing if you aren't looking out for it.PeterDonis said:Phrak, I think you may be assuming a different convention for the units of k. In the convention DaleSpam is using, the phase [itex]\phi[/itex] has the same units as the "position vector" r; that means k is dimensionless (see the formulas in post #73). You may be thinking of a different convention where k is a "wavenumber vector" and has dimensions of inverse length, so that the phase is dimensionless. The latter is the convention I learned when I took wave mechanics in school; the reason for adopting it was that if you describe a wave as a complex exponential (or sines and cosines), the argument of the exponential (or the sines and cosines), which is the dot product k . r, has to be dimensionless.
