Planck function expressed in Wavenumber?
1 reply · 8K views · last reply
nordmoon
I am checking some equations for my simulation and are looking at the Planck function. My question involves the constant used for the Planck function expressed in Wavenumbers. I have found this expression for the function (http://pds-atmospheres.nmsu.edu/education_and_outreach/encyclopedia/planck_function.htm) but I don't understand where the unit comes from for the first Planck constant alpha1 = 2 h c^2 = 1.191066 · 10^-5 mW · m-2 · steradian-1/cm-4? I would like to understand this before I use it. There is another expression for the first Planck constant including pi but has a different unit.
I guess I am looking for a Planck function expression which uses wavenumbers, but it would be nice to see how alpha 1 is obtained.
Planck function dependent on wavenumber w (cm-1)
B(T,w) = (alpha1 w^3)/[exp(alpha2 w/T) - 1]
alpha1 = 2 h c^2 = 1.191066 · 10^-5 mW · m-2 · steradian-1/cm-4 <-- how?
when
h is Planck's constant (6.62620 · 10^-34 Joule second)
c is the speed of light (2.99793 · 10^8 m/second)
I have found another source that
alpha1 = 2 pi h c^2 = 3.741 771 18(19) × 10−16 W·m²
Putting in the numbers I obtain:
alpha1 = 2 h c^2 = 1.19107 * 10 ^-12 W/cm^2 = 1.19107 * 10 ^-16 W/m^2
This is not, 1.191066 · 10^-5 mW · m-2 · steradian-1/cm-4 .. where does the unit steradian-1/cm-4 come from?
I might add that I did find a few papers using this number, C1 = 1.191062£10^-12 W cm^2 /sr, but it still does not explain the origin of the two unit values. (http://www.iop.org/EJ/article/1674-1056/17/11/038/cpb_17_11_038.pdf?request-id=2a611551-3e23-4cae-9cb4-58c619d41cbe) I couldn't find the original when looking at references..
From my astronomy sources, " A steradian is defined as the http://en.wikipedia.org/wiki/Solid_angle" subtended at the center of a sphere of radius [itex]r[/itex] by a portion of the surface of the sphere whose area, [itex]A[/itex], equals [itex]r^2[/itex] "
Steradians are commonly used in astronomy and astrophysics (where Planck's constant is frequently used as well). Outside of astronomy/astrophysics, I do not know where else one might find the unit used.
