Please help solving this problem: Reading & Writing Records in a Structure
The discussion revolves around a programming issue where a user is unable to modify a specific record in a binary file without erasing the other records. The user has implemented a program that reads, modifies, and writes back records but finds that only the modified record remains, while others are lost. The solution involves using the correct file opening flags; specifically, using `ios::in | ios::out | ios::binary` prevents existing data from being overwritten. The user acknowledges the mistake of not understanding the implications of file modes and expresses a desire to move on to the next chapter after resolving the issue. This highlights the importance of understanding file handling in programming to avoid data loss.
yungman
Hi
I have a funky problem I have been working on for over a day, it is supposed to be quite simple, but I have funny result. What the program does is to pick out one of the five records(of structure) stored in the file, modify it and store back into the file in the same position. It supposed to only change the chosen one and leave the others alone. But instead it erase the others. I went through it so many times and I cannot figure this out. This is modification of an exercise from the book. I finally keyed in the exact program from the book, it did the same thing.
There is one program ( 12.20) that create the file with 5 of the records. This program pick one to edit. Because this program destroy the data inside the file, I put exercise 12.20 in line1 to line35. I made it into comment to get it out of the way after creating the Inventory.dat.
C++:
/*//12.20 create file of blank struct inventory records
#include <iostream>
#include <fstream>
#include <iomanip>
using namespace std;
const int d_size = 31;
const int numRec = 5;
struct invItem
    char desc[d_size];
    int qty;
    double price;
int main()
    fstream inventory;
    int index = 0;
    invItem record;
    cout << " Size of inventory = " << sizeof(invItem) << "\n\n";
    inventory.open("Inventory.dat", ios::out | ios::binary);
    for (index = 0; index < numRec; index++)
        cout << " Record  " << index << endl;
        cout << setw(25) << left << " Description: ";
        cin >> record.desc; cout << endl;
        cout << setw(25) << left << " Quantity: ";
        cin >> record.qty; cout << endl;
        cout << setw(25) << left << " Price: " << "$";
        cin >> record.price; cout << "\n\n";
        inventory.seekp(index * sizeof(invItem), ios::beg);
        inventory.write(reinterpret_cast<char*>(&record), sizeof(record));
    inventory.close();
    return 0;
//12.22 edit record created by 12.20
#include <iostream>
#include <fstream>
#include <iomanip>
#include <string>
const int d_size = 31, numRec = 5;
struct invItem
    char desc[d_size];
    int qty;
    double price;
void displayRec();
void modify(long);
int main()
    char again, choose;    int sel;
//Display all the records in the file
    cout << " Do you want to see all records? "; cin >> choose;
    if(tolower(choose) == 'y')  displayRec();
//Read and edit particular file.
    do
        cout << " What record you want to read and edit? ";    cin >> sel; cout << "\n\n";
        modify(sel);
        cout << " Do you want to edit another record? "; cin >> again;
    } while (tolower(again) == 'y');
    return 0;
void displayRec()
    fstream inven;    invItem rec; long select = 0;
    inven.open("Inventory.dat", ios::in | ios::binary);
    inven.read(reinterpret_cast<char*>(&rec), sizeof(invItem));
    do
    {    cout << " Record   " << select << endl;
        cout << setw(25) << left << " Description: " << rec.desc << endl;
        cout << setw(25) << left << " Quantity: " << rec.qty << endl;
        cout << setw(25) << left << " Price: " << "$" << rec.price << "\n\n";
        select++;
    } while (!inven.eof());
    inven.close();
void modify(long index)
    char choose, again = 'n';fstream inventory;
    invItem record; //It's object of struct invItem.
    inventory.open("Inventory.dat", ios::in | ios::binary);
    inventory.seekg(index * sizeof(invItem), ios::beg);
    inventory.read(reinterpret_cast<char*>(&record), sizeof(invItem));
    cout << setw(25) << left << " Description: " << record.desc << endl;
    cout << setw(25) << left << " Quantity: " << record.qty << endl;
    cout << setw(25) << left << " Price: " << "$" << record.price << "\n\n";
    inventory.close();
    cout << " Do you want to change change record " << index << "? ";
    cin >> choose; cout << "\n\n";
    if (tolower(choose == 'y'))
        cout << setw(25) << left << " Description: "; cin >> record.desc; cout << endl;
        cout << setw(25) << left << " Quantity: "; cin >> record.qty; cout << endl;
        cout << setw(25) << left << " Price: " << "$"; cin >> record.price; cout << "\n\n";
//Display what you entered
        cout << " You entered new data in record " << index << endl;
//Write to file
        inventory.seekp(index * sizeof(record), ios::beg);
        inventory.close();
I first run the program to read the invItems as shown here before editing. You can see the 5 records.
I used all the tools I know how with debugger. It ALL works UNTIL line 108 to line 110. I verify I wrote in the new data in line 103 to 106 that I got the right data written into record. I edited record #2. But after writing, I closed the program and restart the program so I can read back the 5 records, all the other ones got erased as shown.
Like I said, I finally key in the exercise from the book, it did exactly the same thing. In the exercise, they won't know because it only read back the one they changed. As you see, the #2 record I changed is there. Just the rest got erased.
Now I am at a lost, will line 108 to line 110 erase the other record when editing the chosen one? I thought seekp() and write() only write over the one that is pointing and leave the others alone.
Another thing is, I cannot upload the Inventory.dat here, I even change to .txt and still won't work. Another funny thing is If I create the Inventory.dat with another program and just copy into the folder of this program, It WON'T work. Got to create by this program. Don't ask me why. That's why I finally copy 12.20 onto this program from line 1 to line 35. Use it to create the Inventory.dat for the program to use.
I know this is a long program, I exhausted everything I know how to do and I can't fix it. The problem is really in line 108 to 110.
Please help.
Thanks
Technology news on Phys.org
If you were using fopen, I would say you needed to open it with the "r+" flag.
Since you are using fstream:: open, I would try ios::in | ios:: out | ios::binary.
Likes yungman
Why using ios::in | ios:: out | ios::binary works?
I did it in ios::in, then I make sure I close the file, then open in ios:: out. Isn't it the same?
I wasted over a day, never think that will make a difference!
Thanks
yungman said:
I did it in ios::in, then I make sure I close the file, then open in ios::out. Isn't it the same?
No. If you open a file for output (i.e., with ios:: out), if it already exists, it will be overwritten.
https://docs.microsoft.com/en-us/cpp/standard-library/output-file-stream-member-functions?view=vs-2019 said:
Creating a file. If the file already exists, the old version is deleted.
C++:
ofstream ofile("FILENAME", ios::out);
Likes yungman
Yes, it's my fault, I was so sure it doesn't matter and I skipped reading deeper that ios::in | ios::eek:ut is the only way that won't delete the existing content other than the one needs to be changed.
Can you delete this thread, this is the end. Now I am ready to move on to Chapter 13 Classes.
Thanks
We will keep this thread - who knows how many others will need this tip.
Hi Mark
I want to use this threat to thank you for kept mentioning streaming operators <<, >> vs member function getline() and get(). I was busy experimenting with file object streaming vs file.write()/file.read() member functions, by the time I finish, you closed that thread already. I thought I thank you here while this thread is still open.
I studied through like 15 pages of Classes, that really open my eyes on the names that you guys use all the time.
Like int x =5, y=10; If I am correct, int is the datatype, it's a Class. x and y are Objects of datatype int. x and y are both INSTANCE of datatype int. 5 and 10 are Object data. Did I get this right?
Like fstream is a datatype ( Class), fstream outFile declares outFile an Object of fstream. With that, I can use member function read(), write(), seekp() etc. to work on the data. These are the hardest part for me and it was like Russian to me before when people using these terms.
It is very interesting. I don't have any question, it's still quite simple at this point ( only 15 pages in!). I budgeted one month for this chapter, one month for chapter 14 and another month for chapter 15 on Inheritance and Polymorphism. That's should be a generous time frame so I can go back and re-visit stuffs in the pass chapters with the new knowledge.
thanks
int is the datatype, but it's not a class. Same is true for char, short, long, float, etc.
No, they are not objects. They are just variables of type int.
An object is an instance of some class, but x and y are just variables of type int.
Right. fstream is a class, and outFile is an instance of that class (an object). The fstream class has member functions, and maybe some member data -- I'll have to check.
Likes yungman
Ha ha, I guess I reached a little too far. I was wondering where are the member functions of int, char etc. I know +, -, *, / etc. are not member function like append(), length() in String Class, nor read(), seekp() of fstream.
I'll get there...slowly.
Thanks
int, char, short, long, float, double, and a few others are built-in types.
+, -, *, /, %, >, >>, <, !, *, &, and others are operators, some of which can be overloaded in C++.
Likes yungman
Right. Have you heard the expression "If we work any faster, we'll never finish!"?
I might think about starting from the beginning, now that you have the background to understand what the book was saying then.
