Plotting a Suitable Graph to find Emissivity of Tungsten Filament
The discussion focuses on determining the emissivity of a tungsten filament using two different graphing methods based on the equation Q = pσ2πal(T^4 - t^4). The first method plots Q against Θ, yielding a gradient of dQ/dΘ = pσ2πal, resulting in an emissivity value of p = 0.61. The second method plots lnQ against lnΘ, leading to an intercept value of ln(pσ2πal) and an emissivity of p = 0.052. The consensus is that the first method is correct, as it directly correlates to the linear relationship without the complications introduced by logarithmic transformations.
  • Understanding of thermal radiation principles
  • Familiarity with the Stefan-Boltzmann Law
  • Knowledge of linear regression analysis
  • Basic algebraic manipulation skills
  • Study the Stefan-Boltzmann Law and its applications in thermal physics
  • Learn about linear regression techniques for data analysis
  • Explore the implications of emissivity values in material science
  • Investigate the effects of temperature on emissivity measurements
Researchers, physicists, and engineers involved in thermal analysis, material science, and those specifically studying the thermal properties of tungsten and similar materials.
Invertedzero
Plotting a suitable graph to find emissivity of tungsten
It is given that:
Where Q is the Energy Loss Rate, p is Emissivity and T,t are the wire and room temperature. Other symbols are constant.
I have data for Q and (T^4- t^4), which for simplification purposes i'll call Θ.
I need to find p, which is the best way of plotting data to do this?
1/ Plotting Q against Θ -> Linear Line of Best Fit -> Gradient dQ/dΘ = pσ2πal -> (p = 0.61)
2/ Plotting lnQ against lnΘ -> Linear Line of Best Fit -> Intercept = ln(pσ2πal) -> (p = 0.052)
I may be overlooking something, but i don't understand why they get different values and which is correct, or if there's a silly step in the algebra. Any help would be greatly appreciated, as I'm a bit stuck. If it could also be explained why one is more appropriate, and why the other isn't, if it isn't, that's also be helpful.
It is given that:
I have data for Q and (T^4- t^4), which for simplification purposes i'll call Θ.I need to find p, which is the best way of plotting data to do this?
2/ Plotting lnQ against lnΘ -> Linear Line of Best Fit -> Intercept = ln(pσ2πal) -> (p = 0.052)I may be overlooking something, but i don't understand why they get different values and which is correct, or if there's a silly step in the algebra. Any help would be greatly appreciated, as I'm a bit stuck. If it could also be explained why one is more appropriate, and why the other isn't, if it isn't, that's also be helpful.
Method 1 is right since you have [tex]Q = A\theta[/tex] and thus is in the form y = mx + b, b = 0 and A = the slope of the line. There is no reason to take the natural log of both sides, it just makes your job harder. Also,
[tex]lnQ = \ln(A\theta) = lnA + ln\theta[/tex] Which is not the same as y = mx + b.
Hi, thanks for your response. So does 0.6 seem like a resonable value for the emissivity of a tungsten filament? Because online I've seen quite a range of values, but none as high as 0.6, and I'm pretty much certain the rest of the calculations are correct.
Also could you please explain to me why
because i would have though lnA would be essentially the lnm from y =mx + b form. Hence if i ignore the ln Q and ln theta, the intercept of this new graph should be the log of the gradient of the first? I tried it with some basic examples like y=2x and y=x^3 and it seemed to work, but with the experimental calculations I've made the two results of dQ/dtheta and the log method don't correlate, and I'm trying to figure out which is wrong.
