Point charge on a string in an electric field
The discussion revolves around calculating the magnitude and sign of a point charge suspended by a string in a uniform electric field of 9000 N/C. The point charge has a mass of 1.0 g and is positioned 1.0 cm above the lowest point of a 53 cm string. The equilibrium conditions are analyzed using the equations T*cos(θ) = mg and T*sin(θ) = qE, where T is the tension in the string, m is the mass, g is the acceleration due to gravity, E is the electric field strength, and q is the charge. The correct charge value is determined to be approximately 0.215 μC.
  • Understanding of equilibrium conditions in physics
  • Familiarity with electric fields and forces
  • Knowledge of trigonometric functions and their applications in physics
  • Ability to manipulate equations involving tension, mass, and electric force
  • Study the principles of electrostatics, focusing on Coulomb's Law
  • Learn about the applications of trigonometry in physics problems
  • Explore the concept of tension in strings and its role in equilibrium
  • Investigate the relationship between electric fields and forces acting on charged particles
Students studying physics, particularly those focusing on electromagnetism and mechanics, as well as educators seeking to explain the concepts of electric fields and forces in equilibrium scenarios.
swede5670
I need some help solving this question, it is the last one I have to do and I'm not sure how to solve it.
A point charge (m = 1.0 g) at the end of an insulating string of length 53 cm is observed to be in equilibrium in a uniform horizontal electric field of 9000 N/C with the charge 1.0 cm above the lowest (vertical) position. If the field points to the right determine the magnitude and sign of the point charge.
Find Magnitude in C:
T*cosTheta = mg
T*sinTheta = F(elec) = qE
I found this question on a thread from a while ago but I'm not sure entirely what it is saying. Since I have those equations I need to solve for T in the first one to insert it in the second
T*cosTheta = mg
T=mg / Cos(theta)
When I plug that into the second equation
(mg/cosineTheta) * sineTheta = qE = F(elec)
My question is, do I need all three parts of this last equation? Or can I simplify it to this:
Even if I do this, how do I figure out the angle?
And in this case what does E represent?
I tried this, but the answer was incorrect. Can you see what I did wrong?
52 | \ 53
| T \
So the point charge is basically the dobber of a simple pendulum. In this case you have two forces acting on it: gravity, and electrostatic force. Electrostatic force can be described as:
F = E * q
where F is the force vector, E is the electric field vector and q is the charge on the particle. This force vector is directed parallel with the electric field (to the right).
So now look at gravity:
F = m * g
where m = mass of the particle and g = force of gravity (9.8 kg/s^2). Give a 1 g (.001kg) particle, the gravitational force is .0098 N). This is directed straight down (toward the earth).
The string will counter-act both of these forces and can be described as:
Fx = F cos T
Fy = F sin T
Give the diagram above:
sin T = 52 / 53
(because the particle is 1 cm above the lowest point and the string is 53cm long)
So, Fy has to counteract gravity:
Fy = F sin T = m * g
F * (52/ 53) = 0.0098 N
F = 0.0098 * 53 / 52
So Fx has to counteract the electrostatic force:
Fx = F cos T = E * q
Solve for q as:
q = (F cos T) / E
Where F = 0.0098 * 53 / 52
T = arcsin (52/53)
E = 9000 N/C
Plugging in these values:
1.376 * [cosine{arcsin (52/53)}]
1.376 * .999999
q=1.375999/9000
q=1.5288e-4
But this is wrong for q, does anyone one know what went wrong?
The first thing to do is figure the angle.
That's determined by the height of 1 cm.
That means that the Cos of the angle with the vertical must be
(53-1)/53 = 52/53
Cos-1(52/53) = angle
The Tangent of that angle is the ratio of the 2 forces ... mg down and the Fe horizontally - then isn't it?
Ok so cos-1 (52/53) = 11.14 degrees
So can I plug that into the equations I was given up above?
T*cos(11.14) = mg
T*sin(11.14) = F(elec) = qE
I would need to convert g=9.81 m/s to g=0.00981 km/s to get coulombs correct?
If that does work,
T= (0.00981 * 1)/cos(11.14)
T=.009998389
.009998389 * sin(11.14) =qE
[.009998389 * sin(11.14)]/E = q
.0019317587 / E = q
.0019317587 / 9000 = q
2.146398 e-7
Correct?
T*cos(11.14) = mg
I'd go from here with T = mg/cos(11.14)
So ...
q*E = tan(11.14)*mg
If that does work,
T=.009998389
.0019317587 / E = q
2.146398 e-7
Correct?
I'd use the previous equation in SI units and then the answer is already in C.
q = .197*.001*9.81/9000
It yields your answer.
But I would express it as .215 μC
The answer they are looking for is in C though.
  • · Replies 22 ·
