Point charge on a string in an electric field
The problem involves a point charge suspended by a string in a uniform electric field, requiring the determination of the charge's magnitude and sign while in equilibrium. The context includes concepts from electrostatics and mechanics, particularly the balance of forces acting on the charge.
  • Mixed
  • Participants discuss the use of trigonometric relationships to find the angle of the string based on the height of the charge above the lowest point. There are attempts to derive equations relating tension, gravitational force, and electrostatic force. Questions arise about the necessity of all parts of the equations and how to simplify them.
Several participants are exploring different methods to calculate the charge, with some providing calculations and others questioning the correctness of their approaches. There is an ongoing examination of the relationships between the forces and the angles involved, but no consensus has been reached on the correct value of the charge.
Participants are working under the constraints of the problem statement, including the specific values for mass, electric field strength, and the geometry of the setup. There is some confusion regarding unit conversions and the application of gravitational acceleration in calculations.
swede5670
I need some help solving this question, it is the last one I have to do and I'm not sure how to solve it.
A point charge (m = 1.0 g) at the end of an insulating string of length 53 cm is observed to be in equilibrium in a uniform horizontal electric field of 9000 N/C with the charge 1.0 cm above the lowest (vertical) position. If the field points to the right determine the magnitude and sign of the point charge.
Find Magnitude in C:
T*cosTheta = mg
T*sinTheta = F(elec) = qE
I found this question on a thread from a while ago but I'm not sure entirely what it is saying. Since I have those equations I need to solve for T in the first one to insert it in the second
T*cosTheta = mg
T=mg / Cos(theta)
When I plug that into the second equation
(mg/cosineTheta) * sineTheta = qE = F(elec)
My question is, do I need all three parts of this last equation? Or can I simplify it to this:
Even if I do this, how do I figure out the angle?
And in this case what does E represent?
I tried this, but the answer was incorrect. Can you see what I did wrong?
52 | \ 53
| T \
So the point charge is basically the dobber of a simple pendulum. In this case you have two forces acting on it: gravity, and electrostatic force. Electrostatic force can be described as:
F = E * q
where F is the force vector, E is the electric field vector and q is the charge on the particle. This force vector is directed parallel with the electric field (to the right).
So now look at gravity:
F = m * g
where m = mass of the particle and g = force of gravity (9.8 kg/s^2). Give a 1 g (.001kg) particle, the gravitational force is .0098 N). This is directed straight down (toward the earth).
The string will counter-act both of these forces and can be described as:
Fx = F cos T
Fy = F sin T
Give the diagram above:
sin T = 52 / 53
(because the particle is 1 cm above the lowest point and the string is 53cm long)
So, Fy has to counteract gravity:
Fy = F sin T = m * g
F * (52/ 53) = 0.0098 N
F = 0.0098 * 53 / 52
So Fx has to counteract the electrostatic force:
Fx = F cos T = E * q
Solve for q as:
q = (F cos T) / E
Where F = 0.0098 * 53 / 52
T = arcsin (52/53)
E = 9000 N/C
Plugging in these values:
1.376 * [cosine{arcsin (52/53)}]
1.376 * .999999
q=1.375999/9000
q=1.5288e-4
But this is wrong for q, does anyone one know what went wrong?
The first thing to do is figure the angle.
That's determined by the height of 1 cm.
That means that the Cos of the angle with the vertical must be
(53-1)/53 = 52/53
Cos-1(52/53) = angle
The Tangent of that angle is the ratio of the 2 forces ... mg down and the Fe horizontally - then isn't it?
Ok so cos-1 (52/53) = 11.14 degrees
So can I plug that into the equations I was given up above?
T*cos(11.14) = mg
T*sin(11.14) = F(elec) = qE
I would need to convert g=9.81 m/s to g=0.00981 km/s to get coulombs correct?
If that does work,
T= (0.00981 * 1)/cos(11.14)
T=.009998389
.009998389 * sin(11.14) =qE
[.009998389 * sin(11.14)]/E = q
.0019317587 / E = q
.0019317587 / 9000 = q
2.146398 e-7
Correct?
T*cos(11.14) = mg
I'd go from here with T = mg/cos(11.14)
So ...
q*E = tan(11.14)*mg
If that does work,
T=.009998389
.0019317587 / E = q
2.146398 e-7
Correct?
I'd use the previous equation in SI units and then the answer is already in C.
q = .197*.001*9.81/9000
It yields your answer.
But I would express it as .215 μC
The answer they are looking for is in C though.
  • · Replies 22 ·
