Pointers for the solution of 2nd order DE with variable coefficient
6 replies · 4K views
crawf_777
Hi,
I am looking at the following 2nd order DE with variable coefficient:
y''(x)-(1/x+7)y(x)=0
I would be grateful for any help in regard to methods which may be applied to such an equation.
Many thanks in advance!
C.
Typically such an equation can be solved by looking for a series solution.
The first thing I would do is multiply both sides by x:
[tex]x\frac{d^2y}{dx^2}- (7x+ 1)y= 0[/tex]
Because of that x in the leading term you will need to use "Frobenius' method"- we look for a solution of the form
[tex]y(x)= \sum_{n=0}^\infty a_nx^{n+c}[/tex]
where c is not necessarily a positive integer.
Then
[tex]y'(x)= \sum_{n=0}^\infty (n+c)a_nx^{n+c- 1}[/tex]
[tex]y''(x)= \sum_{n= 0}^\infty (n+c)(n+c-1)x^{n+c- 2}[/tex]
Put that into the equation to get sums of powers of x equal to 0.
Choose c by looking at the coefficient of [itex]x^0= 1[/itex] and asserting that [itex]a_x[/itex] (n=0) is not 0.
Once you know c, combine like powers and set the coeficients equal to 0. You will get a recursive formula for the coefficients, [itex]a_n[/itex].
Thanks for your help HallsofIvy! Much appreciated.
C.
Hello !
This ODE can be analytically solved. The closed form for the general solutions involves the Kummer function and the Tricomi function ( i.e. the confluent hypergeometric functions)
Hi JJacquelin,
Thanks for your pointer; I got a series solution together ok, though it seems to blow up strangely. Anyway, I would certainly be interested in seeing the analytical form of the solution to said de. I’ll have a look at those functions that you suggested.
Cheers,
C
Hello crawf_777
The analytical solution is :
Hi JJacquelin,
Thanks for that! Very much appreciated!
C
