How Does the Poisson Distribution Calculate Tornado Probabilities in Georgia?
The discussion focuses on calculating tornado probabilities in Georgia using the Poisson distribution, specifically with a mean (λ) of 2.4 tornadoes per year. The probabilities for at most 2 tornadoes (56.97%) and at least 1 tornado (~90.93%) were calculated using the formula P(X = x) = e^(-λ) (λ^x/x!). For the scenario of exactly 10 tornadoes over 7 years, the mean for 7 years is adjusted to λ = 16.8, leading to a probability of P(X=10) = e^(-16.8)(16.8^10/10!) ≈ 2.5%. The importance of correctly using exponential notation in calculations was emphasized throughout the discussion.
  • Understanding of the Poisson distribution and its parameters
  • Familiarity with the formula P(X = x) = e^(-λ)(λ^x/x!)
  • Basic knowledge of probability calculations
  • Ability to interpret statistical results in a real-world context
  • Research the application of the Poisson distribution in real-world scenarios
  • Learn about the implications of changing the mean (λ) in Poisson distributions
  • Explore advanced statistical software tools for calculating probabilities
  • Study the differences between Poisson and other probability distributions, such as the binomial distribution
Students studying statistics, meteorologists analyzing tornado data, and researchers interested in probabilistic modeling of natural events.
King_Silver
The number of tornadoes per year, in Georgia, has a Poisson distribution with a mean of 2.4 tornadoes. Calculate the probability that in any given year, there will be:
(i) At most 2 cases.
(ii) At least one case.
(iii) Calculate the probability that there will be exactly 10 tornadoes in the next seven years.
λ = 2.4 (Mean),
Formula: P(X = x) = e-λ (λx/x!)
Where X = number of events at given internal
e = ~2.71
x = 0,1,2,3,4……..n (where n = any number)
(i)At most 2, Therefore we need to examine P(X=0),P(X=1),P(X=2)
P(X=0) = e-2.4(2.40/0!) = 0.090717953
P(X=1) = e-2.4(2.41/1!) = 0.217723087
P(X=2) = e-2.4(2.42/2!) = 0.261267705
0.0907+0.2177+0.2612 = 0.5697 (56.97%)
(ii) At least 1, Therefore we need to examine P(X=0). Then 1-P(X=0)
1-0.090717953 = 0.90929 (~90.93%)
(iii) At least 1, Therefore we need to examine P(X=10). Over 7 years
P(X=3) = e-2.4(2.43/3!) = 0.209014164
P(X=4) = e-2.4(2.44/4!) = 0.125408498
P(X=5) = e-2.4(2.45/5!) = 0.060196079
P(X=6) = e-2.4(2.46/6!) = 0.024078431
P(X=7) = e-2.4(2.47/7!) = 0.008255462
P(X=8) = e-2.4(2.48/8!) = 0.002476638
P(X=9) = e-2.4(2.49/9!) = 0.000660436
P(X=10) = e-2.4(2.410/10!) = 0.000158504
Part (iii) is where I run into an issue. The question states it must be exactly 10 tornadoes in the space of 7 years. Meaning there could be any combination of tornadoes in the years. For example; the first year could have all 10 tornadoes, with the following years not having none. Or the first year could have none, the second year could have 3, then the remaining 6 tornadoes in the following years.
How I was going to attempt this final part was by summing these values up. This would give the maximum probability per year, then multiply this by 7 (as 7 years) I doubt this is correct.
Where does the 7 years come into the formula? and is it correct to assume that calculating P(X= 1 to 10) is relevant to the question?
First, please use the superscript function to make your expressions clear (on grey bar at the top of the text window). Thus
P(X=x) = eλx/x!
P(X=9) = e-2.4(2.49/9!) etc.
Now do you know, or can you work out, a formula for the 7 year case? You know that the mean for 1 year is 2.4. What do you think is the mean for 7 years? Using this, can you suggest a formula for P(X=x) in 7 years?
Likes King_Silver
P(X=x) = eλx/x!
At least 10, Therefore we need to examine P(X=10). Over 7 years
λ = (2.4)(7yrs) = 16.8
P(X=10) = e-2.4(16.810/10!) = 0.02495 (~2.5%)
is this correct?
is this correct?
If ## \lambda ## has changed to 16.8, you need to use ## e^{-16.8} ## in the formula. Also, use ^ to get an exponent in Latex. The formula reads ## \lambda^k ##.
is this correct?
If your e-2.4 means e^(-2.4) ("e to the power -2.4") then yes, it is correct.
As mjc123 points out in #2, you MUST distinguish a power from another type of operation. So, either use the "superscript" button (labelled "##x^2##" in the grey ribbon at the top of the input panel) or else use "^", to write a^b instead of a b (when you mean ##a^b##). (If I were marking your work I would mark it wrong as you have submitted it.)
@Ray Vickson It's very early in the morning, but shouldn't it (the normalizing factor of the Poisson distribution) be ## e^{-16.8} ##? I believe the OP got it incorrect.
Charles Link said:
@Ray Vickson It's very early in the morning, but shouldn't it be ## e^{-16.8} ##? I believe the OP got it incorrect.
My bad! I calculated it as if it was e-16.8 just left it as 2.4 when I wrote it! my bad. Thanks for the help though!
My bad, again; not sure why I did that. Was in a rush responding. Appreciate the feedback. Cheers!
Likes Charles Link
Yes, of course: I meant that the final numerical answer in (iii) was correct.
Likes Charles Link
  • · Replies 35 ·
