Poisson spot with single photons
The discussion revolves around the concept of observing a Poisson spot using single photons, exploring the implications of wavefunctions and their macroscopic dimensions. Participants consider the feasibility and significance of such experiments, touching on theoretical and experimental aspects.
  • Some participants propose that conducting an experiment with single photons to observe a Poisson spot could demonstrate the macroscopic nature of wavefunctions.
  • Others mention the obscuring disc diameter observed in related experiments, questioning whether it could be larger and discussing the implications of photon wavefunctions as spheres.
  • There is a suggestion that the probability distribution leading to interference patterns in single-photon experiments can be calculated regardless of the diameter of the sphere.
  • Some participants express skepticism about the practicality and interest in conducting experiments with larger spheres, citing the effort versus potential knowledge gained.
  • One participant raises the idea of using mirrors to direct photon probabilities for interference, but this concept is met with confusion and requests for clarification on the experimental setup.
  • There is a discussion about the requirements for observing an Arago spot during a solar eclipse, with differing opinions on whether the sun meets these requirements.
  • Some participants argue that the sun does not qualify as a point source necessary for the expected interference patterns, while others counter that each photon from the sun could still propagate independently.
  • Concerns are raised about coherence and the smoothness of the target in relation to observing interference patterns.
Participants express a range of views, with no consensus on the feasibility or significance of conducting experiments with single photons to observe Poisson spots. Disagreement exists regarding the requirements for observing interference patterns and the implications of photon wavefunctions.
Participants note limitations in understanding the experimental setups and the complexities of interpreting optics experiments. There is also mention of the need for coherence and point sources in relation to observing expected patterns.
Quant
I suppose that when carried out a Poisson spot with photons one at a time
should have to be observed.
I tried to find such experiment but i got 0 result. it seems that nobody cared
about that. But i think such experiment would be very important as it will show
that the wavefunction can have macroscopic dimension (not just 0.5 mm but
much more).
So why there are not experiments for Poisson spot with single photons?
Thank you
pines-demon said:
Thank You @pines - demon. As far as I interprete the data the obscuring disc diameter is 4 cm.
Do you think this diameter can be greater? In my opinion the wavefunction of a photon should be
a sphere with R=c.t so much greater diameter should be possible in principle. Then the Arago
spot may be possible with opposite points/parts of the sphere using mirrors if this is true, do you think?
If you think it is important, why not do the experiment yourself? That's probably more effective than complaining on a message board that physicists are all out measuring what they are interested in instead of what you are interested in.
Quant said:
Thank you
"Wavefunction of a photon" is a somewhat tricky idea, in part because when we're talking wavefunctions we're usually talking non-relativistic QM - and photons are among the most egregiously relativistic things around. But with that said, there is no reason to doubt that the probability distribution that leads to dot-at-a-time interference patterns in single-photon experiments can be calculated in the same way no matter the diameter of the sphere.
And that's why there's not a lot of interest in actually doing the experiment with larger spheres: it's a lot of work with small chances of learning anything we didn’t already know.
Then the Arago
Now this I totally do not understand. Where do mirrors come into it? What experimental setup are thinking of, and having calculated the expected result, what do you expect to learn from this setup.
Quant said:
Thank you
If I understand the graph correctly the diameter of the spot is 1 cm.
Quant said:
In my opinion the wavefunction of a photon should be a sphere with R=c.t so much greater diameter should be possible in principle.
Physically yes, in practice it depends, one would have to take a look at the experimental set-up, but I am no good at interpreting optics experiments, see other comments.
Short answer: money, time, lot of efforts. But as in fact the classical EM wave is a collection of the separate single photon's "wavefunctions"/probabilties, a classical experiment is also a confirmation for the spherical propagation of "WF"/Pr of single photons.
1 cm? Why? The shadow spreads from -20 mm to 20 mm. Or i don't take in account the distance behind the disk/ball they used?
I got the idea the Arago spot should exist by solar eclipse? Any info?
Yes surely though there are some variants like Byalnizki-Birula, Sipe etc.
Do you agree that as the EM wave is a collection of single photon's probabilities, classical (e.g. huge number of photons) Arago spot experiments confirm the spherical spreading of probability for single photons?
Do you have opinion about Arago spot by solar eclipse?
If the probability spreads like a sphere (for a source of the photon - a free stationary atom) than probabilities from the opposite ends of that sphere should be able to interfere but mirrors are needed to direct them in one point. Of course this maybe done with fiber optics. Expected result is confirmation of spherical propagation of probability for single photon.
As you think this is completely sure I would say that in all books (say 20) i read on QM there is not a word about how does the probability propagation of single photons look like.
That's fine, but don't expect people to be convinced by the argument "my time is too valuable. Your time, on the other hand...."
Or, in another context: "Asps. Very dangerous. You go first."
Further, the classical version of this is done by freshman university students. If you want to do this one photon at a time, you start with that, add a dark box, a digital camera, an optical filter, and some stacking software of the kind used by amateur astronomers. That's it.
You don't need a particle accelerator, or a nuclear reactor, or a rocket, or even a vacuum chamber.
Another "it's too much work for me to do - you guys do it!"
You had two options:
A. Plug in the numbers into the equation Wikipedia gives you.
B. Type that into Google.
Again, you decided your time was too important, but our time isn't. How to win friends and influence people.
The answer is "no", as the sun is not even remotely close to the light source requirements.
What requirements are you talking about? Every photon from the visible sun disk should
propagate on its own with its own 'wave function'/probability distribution which must pass
the both sides of the moon (because its in almost vacuum) and then interfere only with itself.
So the sun disk is a collection of point sources and each must produce an intfr pattern (of
different photons from that point). As the other points don't intf negatively with any other
point there should be a small image of the sun in the centre of the moon shadow. It would
of course be very faint and obscured by many other sources. The non ideal vacuum will also
diminish this Arago spot formation.
Coherence if you anticipate a visible pattern predicted by classical wave optics. Single-photon states if you’re thinking of the dot-at-a-time patterns built up by quantum effects.
A point source. The sun is not even approximately one.
A smooth target. The moon is not even approximately one.
And as a PS, the reason you don't see the Arago/Poisson/Fresnel Spot in an eclipse is classical, not quantum mechanical.
Only in a very, very vaguely heuristic sense.
That should be an indication to you that the concept you are trying to use here, to the extent it even makes sense (see above), is not a very useful one.
What is the EM field respective photons in your view?
PeterDonis said:
That should be an indication to you? that the concept you are trying to use here, to the extent it even makes sense (see above), is not a very useful one.
Now what is concept of a photon?
The problem is that QM is a non-relativistic theory, therefore you should not be surprised that nobody is writing about photons, which are the most relativistic thing you can get.
Nugatory said:
No substitute for a quantum electrodynamics text, but this is a good I-level start: https://www.physics.usu.edu/torre/3700_Spring_2015/What_is_a_photon.pdf
Thank you for effort. But in the article the Fock states (and their superpositions)
are presented as photons. Definitely they are very useful in tackling almost any
problem but are just mathematical constructs. Surely the real life photon can
not be born in whole Universe or can be 'comprised' by infinitely great number
of such Fock photons.
Yes but there is QED where the real photons are presented as superpositions of unphysical Fock
(number) states. As far as I remember Fock himself pointed that out.
"Real Photons" ??
Please be more specific as to what the distinction is here (at least by your definition). Perhaps this is part of our seeming communication problem here.
Maybe you are right. The Fock states are called photons for QED just as a name.
They don't say that they exist. Just the real photons (perceived in detectors and emitted
from atoms) are 'made' by Fock states e.g. QED photons.
This terminology is very misleading. I don't see anywhere in the text that to be stressed
just in contrary. Silently the imaginations are maintained that these the only photons.
Note that also the real QFT fields are regarded (or at least there is such imprint) to
consist of Fock photons.
What does "real" mean in this context? A reference would be a good start. What does "Fock photon" mean?
????? Sorry, not following.
Are the quantum fields not the only underlying reality? Reference David Tong b.e. and anything in QFT.
Of course when QFT fields are real, then quantized by Fock states it it close to mind that
Fock states are what is real. And they are named photons. Ref. your text.
P.S. The Fock states (fixed k vector) are called photons in the text (and not only in it).
  • Skeptical
Huh? When I look outside my window the light that strikes my eye is not real?
This thread seems to have drifted, and in a kind of...um...iconoclastic direction.
Please read my post in its entirety. Do not put sentences out of context.
What I'm saying is that Fock states are not real physical beings but mathematical
constructs.
Very obvious is this also in this example. Let a light that one sees is generated,
by at least two atoms. According Fourier each mode will comprise EM
components of the fields generated by these two atoms. E.g. the Fock states
are mix from two sources. Can a photon come from two sources?
I would like to see some physical arguments if possible but not sematic
qualifications. Such remarks don't clear any scientific problem.
Of course anyone is in his own right to stick to wrong but deeply accepted
notions.
notions.
I think you are crossing the line between asking a question and promoting your own personal theory. (Which we do not do)
The question in the OP was answered. It was even pointed out that you could demonstrate this yourself. You weren't interested in that, which is your choice. Then we went down this long path that has little to do with the original question and seems to have contradictory claims from you: Fock states are real, Fock states are not real.
If people are confused, it's not because they are not reading what you write. It's that they are.
Sure, why not? It’s a quantized excitation of the electromagnetic field, and that field is coming from two sources.
Now if photons had positions and trajectories you would have a convincing example - a trajectory has to have a single starting point - but they don’t.
  • · Replies 33 ·
  • · Replies 16 ·
  • · Replies 81 ·
  • · Replies 64 ·
  • · Replies 32 ·
