Polar to cartesian using e(theta) and e(r)
10 replies · 10K views · last reply
ual8658
Handwritten diagram of a car on a slope at angle theta, with unit vectors e_r along the slope and e_theta perpendicular to it, velocity v pointing down, and the boxed equation j = cos(theta) e_theta + sin(theta) e_r.
NONE
I'm trying to understand why the unit vector in the y direction is that formula. I get that e(theta) and e(r) are unit vectors used with polar coordinates that define direction and are perpendicular to each other always. What I don't get is their relationship with theta to get cartesian unit vectors.
A simple rotation over the angle ##\theta##. Your second picture shows it clearly for ##\bf\hat\jmath##.
For ##\bf \hat\imath## you see ##e_\theta## points in the negative ##\hat\imath##-direction so you get ##\hat\imath = \cos\theta \; e_r - \sin\theta \; e_\theta##
What do you think it should be?
I don't follow.
I don't know what it should be. I originally thought the j vector was just the projection of e(theta) but that clearly cannot be because both j and e(theta) have length 1. Is there a general relationship that might explain how two perpendicular unit vectors in a plane can somehow form this relationship?
ual8658 said:
I don't follow.
Your diagram in post #1 only needs you to read off the sine and cosine components to get this relationship. However, another way is to note that (in Cartesian coordinates):
##j = (0, 1), \ \hat{r} = (\cos \theta, \sin \theta), \ \hat \theta = (-\sin \theta, \cos \theta)##
Then, you simply have to use a bit of vector algebra to express ##j## as a ,linear combination of ##\hat{r}## and ##\hat \theta##.
You can check it from the expressions I gave. A rotation preserves vector lengths
Suppose that ##\theta = 0##. What would j be equal to, ##i_r## or ##i_{\theta}##?
Suppose that ##\theta = 90\ degrees##. What would j be equal to, ##i_r## or ##i_{\theta}##?
I follow this but I wanted the derivation for it.
Ok that first part makes sense. How can you at a glance determine that those two vectors r and theta would lineraly combine to form a vector of length 1?
ual8658 said:
I follow this but I wanted the derivation for it.Ok that first part makes sense. How can you at a glance determine that those two vectors r and theta would lineraly combine to form a vector of length 1?
##\hat{r}## and ##\hat \theta## are linearly independent so form a basis (in fact, they form an orthonormal basis). Any vector, therefore, can be expressed as a linear combination of them.
You can use the basic techniques of solving simultaneous equations to get the coefficients. In this case, we look for coefficients ##a, b## such that:
##a \hat{r} + b \hat \theta = j##
Hence
##a(\cos \theta, \sin \theta) + b(-\sin \theta, \cos \theta) = (0, 1)##
Which implies:
##a \cos \theta - b \sin \theta = 0##
##a \sin \theta + b \cos \theta = 1##
Which leads to the solution ##a = \sin \theta, \ b = \cos \theta##.
Just draw a right triangle anywhere in the domain with j as the hypotenuse, and the other two sides parallel to the local ir and itheta. Then determine the lengths of those other two sides.
Charles Link said:
When you substitute with ## cos(\alpha)=\sqrt{1-sin^2(\alpha)} ## , you then square both sides of the equation and get a quadratic equation in ## u=sin^2(\alpha) ##. (It is actually 4th power in ## sin(\alpha) ## , but there is no ## sin^3(\alpha) ## term and no ## sin(\alpha) ## term=it is quadratic in ## sin^2(\alpha) ##.
Hence
Which implies:
Now it makes sense. Thanks!
I see it now. Thanks!
