Polarized light and refraction
compound
polarized light and refraction!
Hi guys
I need to discuss the polarized light in the waveguide and its refraction at an interface between two different media.
if the light is polarized like in the picture(see attached) and oscillating only up and down (linear polarization), then does the light will be refracted at the interface or not?
my idea is that although the interface is tilted, the angle between electric field and the interface is normal, then no refraction.
I will appreciate if somebody is interested in this problem.
  • Diagram of a light beam travelling right through a slanted interface between a region labelled n=2 on the left and n=1 on the right, with the beam splitting into a straight path labelled A and a bent path labelled B; E points out of the page and B points upward at the left.
The light will be refracted and the angle is given by Snells law independent on it's polarization (as long as the material is not birefringent). Polarization only affects the ratio of light being reflected/ transmitted.
just apply the condition of continuity of normal component of D and continuity of tangential component of E across the interface.see if it does give rise to any refraction amplitude.
