Position as a function of time through a varying gravitational field
JJfortherear
I've been trying to figure this out for a while, since my first semester of physics ended. It's not a homework problem, just something I've been doing for fun. I've spoken with a few people about it and they all say it's just a diff. equation but they can't remember how to solve it, and, unfortunately, I haven't taken diff. equations yet. So the furthest I get is:
x=1/2at^2
a=gmm/(r-x)^2
so plug in a to the first eq. The r-x is the initial radius minus the distance x traveled due to acceleration.
I'm sure this case has been extensively closed, but I just stumbled upon this website and I could find no solution to this problem anywhere else (could just ask one of my soon to be physics professors, but I'd rather know now). Thanks.
just wanted to clarify, one object is considered stationary (mass of something like a planet, but considered as a point, so x approaches r and the acceleration becomes infinite). I'm just looking for how to solve the two equations for x (and i realize that should be gm not gmm for acceleration)
Your first equation is wrong. It's only valid for constant a, which is not the case. It should read d²x/dt² = a. And your second equation is greatly simplified if you shift your x variable to be relative to origin. That way, the equation you are trying to solve is this.
d²x/dt² = -g/x²
I found a solution, which is x = bt^(2/3), but it is obviously the parabolic escape solution, and you need an elliptical one. I'll keep thinking.
d²x/dt² = -g/x²
There's a clever trick to solving this type of ODE, just make use of the chain rule by noticing
[tex]\frac{d^2 x}{dt^2}=\frac{d}{dt}\left(\frac{dx}{dt}\right)=\frac{dx}{dt}\frac{d}{dx}\left(\frac{dx}{dt}\right)=\frac{1}{2}\frac{d}{dx}\left(\frac{dx}{dt}\right)^2[/tex]
This gives you a very simple separable ODE for [itex]\left(\frac{dx}{dt}\right)^2[/itex] as a function of [itex]x[/itex].
[tex]\frac{d}{dx}\left(\frac{dx}{dt}\right)^2=-\frac{2g}{x^2}[/tex]
Huh. That is nifty.
v² = 2g/x+c
Not that much improvement, though... Separable, but the integral for it is NOT pretty.
Edit: I think it might be easier to start with Kepler's laws and take the limit of angular momentum going to zero.
The integral is readily computed and can also be looked up in a table of integrals.
is it really possible to simplify the distance by moving the origin? I've thought about it and any time I try it seems to change the setup.
15K
