Position of particle in inertial reference frame
The discussion revolves around demonstrating that a particle moves in a circular path with constant speed in a fixed inertial reference frame, described by the position vector r = i(x0 + Rcos(Ωt)) + j(Rsin(Ωt)). Participants explore the relationship between the particle's velocity and its circular motion, considering transformations to a non-inertial reference frame. The conversation highlights the mathematical representation of circular motion, specifically using the equations x² + y² = R² and the parametric forms x(t) = Rcos(Ωt) and y(t) = Rsin(Ωt). Ultimately, the participants confirm that the derived equations support the conclusion of circular motion. The discussion emphasizes the mathematical nature of the problem rather than a purely physics-based approach.
jasonchiang97
The position of a participle in a fixed inertial frame of reference is given by the vector
r = i(x0 + Rcos(Ωt)) +j(Rsin(Ωt))where x0, R and Ω are constants.
a) Show that the particle moves in a circle with constant speed
F = mv2/r
r = r'
where r' is the non-inertial reference frame
dr/dt = i(-RΩsin(Ωt)) + j(RΩcos(Ωt))
I can transform it to a non-inertial reference frame v' using
v = v' + (ω × r')
but since r = r' then
v = v' + (ω × r')
But I'm not sure where that leads me
I also had another thought where if the curl of the velocity in the inertial frame is non-zero does that prove the object is moving in a circular motion? Since the curl is a circulation density.
Write the equation for a circle at the origin. Then, if you rewrite the given equation as:
##\vec {r} = x_0\vec {i} + R\cos (Ωt)\vec {i} + R\sin (Ωt)\vec {j}##
does that help? Hint: this is not a physics question. Just math.
AM
Likes gneill
AM
sorry, do you mean a circle centered at the origin? if that's what you mean then
x2 + y2 = R2where x(t) = Rcos(Ωt) and y(t) = Rsin(Ωt) in polar coordinates
then
##\vec {r} = x_0\vec {i} + R\cos (Ωt)\vec {i} + R\sin (Ωt)\vec {j} = x_0\vec{i} + x(t)\vec{i} + y(t)\vec{j}##
or is the last step not needed
Never mind I figured it out.
Thanks for the hint!
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 17 ·
