Position Vectors: Finding Point Q on AB in 2:1 Ratio
  • Thread starter Thread starter geoff18
    Position Vectors
The problem involves finding the position vector of point Q that divides the line segment AB in a 2:1 ratio, where points A, B, and C are defined in three-dimensional space with given position vectors.
  • Participants discuss various methods to approach the problem, including finding the length of segment AB and using similar triangles. Some express uncertainty about how to find the position vector of Q.
There is ongoing exploration of different strategies to solve the problem. Some participants have suggested using vector equations and linear combinations, while others are seeking further hints and clarification on the steps involved.
Participants note that it may not be necessary to find the length of AB, and there is a focus on understanding the geometric relationships between the points involved.
geoff18
Let A,B,C be the three points in R^3 with position vectors
a=(1,-2,0)
b=(-1,1,2)
c=(7,1,6)
respectively.
Find the position vector q of the point Q that divides the line segment AB in the ratio 2:1, (where Q is closer to B.)
i have no idea how to start...
do i find the length of AB first and work out the ratio?
a=(1,-2,0)
b=(-1,1,2)
c=(7,1,6)
respectively.
No, it is not necessary to find the length of AB! You can, for instead, draw horizontal and vertical lines making a right triangle having vertices at A and B. Then "similar triangles" will make your job easy. Just divide the horizontal and vertal lines into 3 parts.
i tried to do that, but i have no idea how to find the position vector of q...
some more hints pleasE? :p
im waiting online for help, so any help is much appreciated.. thanks in advance. =)
Write the vector equation for the line L that contains the segment AB. This equation will be r(t) = a + t*v
In this equation, a is the vector from the origin to point A, and v is the vector from point A to point B. t is the parameter, and r is a vector that goes from the origin to the point on the line L determined by the parameter t.
What vector is represented by r(0)? By r(1)? Can you think of a way to get to a point 2/3 the way along the segment AB?
when r intersects the line?
Each point of the line corresponds to r(t) for some value of t.
so do i have to find t?
how do i find t?
You get to pick t. If I choose t = 0, r(0) = a + 0*v = <1, -2, 0>. This vector goes from the origin to point A. What I'm calling v is the vector from A to B. Since I am multiplying by 0, I don't need to do any calculations with v for this value of t.
What is r(1)?
a=(1,-2,0)
b=(-1,1,2)
c=(7,1,6)
respectively.
Best way to show this is to show there exists a socalled linear combination from Linear Algebra of all three vectors which satisfies that condition.
if the vector are called [tex]v_1,v_2,v_3[/tex]
then a linear combination is [tex]u_1 \cdot v_1 + u_2 \cdot v_2 + u_3 \cdot v_3[/tex]
where the [tex]u_1,u_2,u_3[/tex] are weights...
a=(1,-2,0)
b=(-1,1,2)
c=(7,1,6)
respectively.
Since you apparently did not understand my first response, using "similar triangles" based on the coordinate axes:
The change in x-coordinate form a(1, -2, 0) to b(-1, 1, 2) is -1- 1= -2. 2/3 of that is -4/3. That is, the change in x coordinate from a(1, -2, 0) to point Q is -4/3: the x coordinate of Q is 1+ -4/3= -1/3.
Do the same for the y and z coordinates.
  • · Replies 63 ·
  • · Replies 18 ·
