k9b4
- 109
- 2
Is there any difference between light produced by a positive charge and light produced by a negative charge?
The discussion revolves around the differences, if any, between light produced by positive and negative charges, particularly focusing on oscillating electrons and protons. Participants explore the nature of electromagnetic radiation, its properties, and the implications of charge polarity on the emitted light.
Participants express differing views on whether the light produced by positive and negative charges is fundamentally different, with some arguing for similarities and others for differences based on charge polarity. The discussion remains unresolved regarding the implications of these differences.
Participants reference concepts such as electromagnetic fields, oscillation, and phase differences without reaching a consensus on the implications of charge polarity on the nature of emitted light.
If I have an oscillating electron, and an oscillating proton, oscillating at exactly the same frequency, is there any difference between the electromagnetic radiation produced by these charges?jedishrfu said:what particles are you thinking of?
This is not a homework assignment.jedishrfu said:Is this a homework assignment? If so then what do you think?
Why wouldn't it?jedishrfu said:The electromagnetic field generated from the oscillating charges vibrating at the same rate would be the same.
It wouldn't repel other like charges like you're thinking, it's not an electrostatic field.
k9b4 said:This is not a homework assignment.
I think the electron radiation would repel other electrons, and the proton radiation would repel other protons?
What does this part mean? What force alternates?Drakkith said:the forces alternates from + to -
k9b4 said:What does this part mean? What force alternates?
Hmmm okay.Drakkith said:The electric and magnetic forces alternate polarity (directions). If we use arrows to represent the forces, then the arrows will flip from one direction, to the opposite direction, and then back to the original direction once per cycle.
k9b4 said:Hmmm okay.
So the only difference between electron light and proton light is the starting force polarity? One will start negative and the other positive?
Cool thanks for explainingDrakkith said:I believe that is correct.
To clarify - when the electric field vector points 'upwards', that means that a positive charge at that particular point will experience a force in the upwards direction?sophiecentaur said:You could consider a source of EM radiation in terms of a radio transmitting antenna (and everything can scale, if you could get hold of a suitable 'transmitter' for light). The fields produced and the resulting radiated EM waves can be predicted by merely thinking of the currents sloshing up and down in the wire. This current is normally composed of moving electrons but it needn't be; no one worries about that in Antenna Theory. Point is that polarity of the moving charges doesn't have any bearing on the nature of the EM waves produced - it's just a Current. If you wanted to relate the radiated fields to the 'movement' involved, there would just be a 180 degree phase difference for the different polarities of the charge carriers.
You would have no way of knowing what produced the wave, once it's been launched. There is only one kind of E field and H field.k9b4 said:To clarify - when the electric field vector points 'upwards', that means that a positive charge at that particular point will experience a force in the upwards direction?
So that means that electron light and proton light originating from exactly the same point and with exactly the same frequency will affect a charge some distance away in exactly the same way - except that the charge being affected will be 'up' for the electron light and 'down' for the proton light (or vice versa)?
But if (theoretically) both charges were in the same spot, and oscillating with the same frequency, their waves would be perfectly out of phase - right?sophiecentaur said:You would have no way of knowing what produced the wave, once it's been launched. There is only one kind of E field and H field.
You would be more likely to have success with Positrons in Anti Hydrogen atoms. I wonder if it's been done? Yes - it looks like it has.
