Possibility to shorten the solving procedure (q13)
  • Thread starter Thread starter jack1234
    Procedure
The discussion focuses on optimizing the procedure for solving a physics problem involving kinetic energy and momentum conservation. The user outlines a method using kinetic energy calculations before and after a collision, specifically calculating initial kinetic energy as 31J and initial momentum as 16 kg*m/s. They propose a shortcut using the relationship ke=(p)^2/2m, which is valid only after the collision for a single mass. This approach yields a quicker calculation of kinetic energy after the collision as 25.6J, resulting in a difference of 5.4J.
  • Understanding of kinetic energy calculations (1/2 mv^2)
  • Knowledge of momentum conservation principles
  • Familiarity with the relationship between momentum and kinetic energy
  • Basic algebra for manipulating equations
  • Study the derivation and applications of the kinetic energy formula ke=(p)^2/2m
  • Explore advanced momentum conservation problems in physics
  • Learn about energy loss in collisions and its implications
  • Investigate different methods for solving collision problems in physics
Physics students, educators, and anyone interested in optimizing problem-solving techniques in mechanics, particularly in collision scenarios.
jack1234
For this question:
http://tinyurl.com/294gl5
I am doing in this way:
[1] calculate the kinetic energy before(1/2*m1*u1 + 1/2*m2*u2)
[2] use the conservation of momentum to calculate the velocity after(v=(m1u1+m2u2)/(m1+m2))
[3] calculate the kinetic energy after(1/2*(m1+m2)*v)
this way we can get the answer, it is c
I wish to know is there a way to shorten this procedure by employing the the relationship ke=(p)^2/2m? Of course the answer can be no :)
Yeah, but be careful of shortcuts... be aware of what you're doing...
we can't use p^2/(2m) before the collision... p^2/(2m) is only for 1 mass (in other words we can't use p as the sum of the two momenta and m as the sum of the two masses... that won't give the right answer. but for each individual mass (1/2)mv^2 = p^2/(2m).
the initial momentum = 2*5 + 3*2 = 16kg*m/s
initial energy = (1/2)2*5^2 + (1/2)3*2^2 = 31J
we can use p^2/2m for after the collision, since after the collision we only have 1 mass of 5kg.
16^2/(2m) = 16^2/(2*5) = 25.6J
so it's a little quicker as you don't need to get the velocity...31-25.6= 5.4J
  • · Replies 16 ·
