Possible explanation for kinetic energy
Kinetic energy (K.E.) is derived from the work done on an object, expressed as K.E. = 1/2 mv^2, where m is mass and v is velocity. The relationship arises from integrating the work done, which involves the force applied over a distance, leading to the factor of one-half in the equation. When an object accelerates, the distance covered increases quadratically with time, explaining why K.E. depends on the square of velocity. The discussion emphasizes that understanding calculus and integration is crucial for grasping how these relationships are formulated. Overall, the kinetic energy formula reflects the energy transferred to an object in motion.
physdoc
why does kinetic energy depend on half the square?
if we add up all the velocities does it not produce half a square?
imagine you are pushing a cart and produce a rate of change of displacement i.e. velocity and somebody says you have given K.E. to the cart by pushing through a force F.
now the work being done by you is F.dx if dx is displacement and F is related to change in velocity/momentum - so the energy input
you provided is m.dv/dt . dx for a small time dt involving displacement.
this can be written as m.dv/dx. dx/dt .dx so summing up for all such displacement = m.v.dv integrated from v=0 to v=v and that's the energy .with a factor of 1/2.m. v^2
Please explain further ...I am not familiar with the mechanics of calculus notation.
If you accelerate something at 1m/s/s for two seconds, it goes 4x as far as if you accelerate it for one second. 22=4
Thanks... That is another way to derive it.
when one integrates expression like integral of v.dv the result is v^2/2. people not knowing the integration will sum the values from 0 to v and w
So this is the same as what I said?
what do you mean when you say w
The work done on an object to move it a distance x in the direction of the force applied is Fx. F = ma and a = (v-u)/t ; we also know that x = 1/2 (u+v) t since this is just the average velocity multiplied by time.
Work done = energy transferred = kinetic energy gained. This is m(v-u)/t * 1/2 (u+v)t = 1/2 m (v^2 - u^2). The kinetic energy is defined as the energy due to motion compared to when the object is at rest, so u = 0.
Therefore, KE = 1/2mv^2
w i referred to the total energy imparted to the cart -which is K.E.-work done by the 'push force' which is responsible for the 'motion' the work done is a check on K.E. value. i.e. 1/2. m. v^2
