Potential difference across a resistor
The discussion centers on calculating the potential difference across a resistor in a circuit with two cells of equal emf (E) and different internal resistances (r1 and r2) connected in series to an external resistance (R). The correct condition for the potential difference across the first cell to be zero is established as R = r1 - r2. Participants clarify the importance of using parentheses in equations to avoid misinterpretation and confirm that the potential difference across the internal resistor is equivalent to the terminal voltage of the battery.
  • Understanding of Ohm's Law (E = IR)
  • Familiarity with series circuits and internal resistance
  • Basic algebra for manipulating equations
  • Knowledge of voltage drop concepts across resistors
  • Study the implications of internal resistance on circuit performance
  • Learn about Kirchhoff's Voltage Law in series circuits
  • Explore the effects of varying external resistance on current flow
  • Investigate practical applications of battery configurations in electronics
Students in electrical engineering, physics enthusiasts, and anyone studying circuit analysis and battery behavior in series configurations.
palkia
Two cells of same emf E and different internal resistance r1 and r2 are connected in series to an external resistance R.The value of R for which the potential difference across the first cell is zero is given by
(A) R=r1/r2
(B)R=r1+r2
(C)R=r1-r2
(D)R=r1r2
E=IR[/B]
I first founded the total current in the circuit which came to be-E/R+r1+r2 then used the equation Ir1 to get the potential difference but I am not getting my answer[/B]
What did you get as answer?
What must be the voltage drop at r1 to make this scenario possible?
By the way: It is useful to put brackets around denominators to make clear what is in the denominator. is x/y+z =(x/y)+z (as it would be usually read) or x/(y+z) (what you mean here)?
Potential difference across r1is Er1/(R+r1+r2) so for zero potential difference r1=0 which looks weird
palkia said:
the total current in the circuit which came to be-E/(R+r1+r2)
No, you forgot something.
2E/R+r1+r2
palkia said:
2E/R+r1+r2
Right, but please use parentheses correctly.
If the PD across the first battery is zero, what current would you expect?
E=2E/(R+r1+r2) r1
But why are solving for the terminal voltage of the battery?
palkia said:
E=2E/(R+r1+r2) r1
I believe that equation gives the right answer.
E-Ir1
palkia said:
E-Ir1
I do not see how you got that from the equation in post #7. Please show your working.
E-2 E r1 /(R+r1+r2)
So the potential difference across the interal resistor issame as terminal voltage of the battery?
Right.
palkia said:
E-2 E r1 /(R+r1+r2)
That is not an equation. You had E=2 E r1 /(R+r1+r2). What does that give you for r1 in terms of R and r2?
I am getting R=r1-r2
Right.
  • · Replies 45 ·
