Potential difference across a resistor
15 replies · 3K views · last reply
palkia
Two cells of same emf E and different internal resistance r1 and r2 are connected in series to an external resistance R.The value of R for which the potential difference across the first cell is zero is given by
(A) R=r1/r2
(B)R=r1+r2
(C)R=r1-r2
(D)R=r1r2
E=IR[/B]
I first founded the total current in the circuit which came to be-E/R+r1+r2 then used the equation Ir1 to get the potential difference but I am not getting my answer[/B]
What did you get as answer?
What must be the voltage drop at r1 to make this scenario possible?
By the way: It is useful to put brackets around denominators to make clear what is in the denominator. is x/y+z =(x/y)+z (as it would be usually read) or x/(y+z) (what you mean here)?
Potential difference across r1is Er1/(R+r1+r2) so for zero potential difference r1=0 which looks weird
palkia said:
the total current in the circuit which came to be-E/(R+r1+r2)
No, you forgot something.
palkia said:
2E/R+r1+r2
Right, but please use parentheses correctly.
If the PD across the first battery is zero, what current would you expect?
E=2E/(R+r1+r2) r1
But why are solving for the terminal voltage of the battery?
palkia said:
E=2E/(R+r1+r2) r1
I believe that equation gives the right answer.
palkia said:
E-Ir1
I do not see how you got that from the equation in post #7. Please show your working.
E-2 E r1 /(R+r1+r2)
So the potential difference across the interal resistor issame as terminal voltage of the battery?
Right.
palkia said:
E-2 E r1 /(R+r1+r2)
That is not an equation. You had E=2 E r1 /(R+r1+r2). What does that give you for r1 in terms of R and r2?
