Potential difference across a solenoid
The discussion centers on the derivation of potential difference across a solenoid when the current is changing, specifically referencing the equation for induced EMF as -L*dI/dt and the resistance term -Ir. Participants clarify that the total potential difference is expressed as -L*dI/dt - Ir, while also emphasizing the distinction between EMF and potential difference. A key point raised is that when the current in the solenoid decreases, the induced current aligns with the original current, opposing the change in current direction. This nuanced understanding is crucial for accurately applying Lenz's Law in electromagnetic induction scenarios.
  • Understanding of Lenz's Law in electromagnetic induction
  • Familiarity with the concepts of EMF and potential difference
  • Knowledge of solenoid behavior in electrical circuits
  • Basic principles of circuit resistance and current flow
  • Study the mathematical derivation of induced EMF in solenoids using Lenz's Law
  • Explore the differences between EMF and potential difference in electrical circuits
  • Investigate the behavior of current in circuits with varying resistance and power supplies
  • Learn about the applications of solenoids in real-world electromagnetic systems
Students of electromagnetism, electrical engineers, and educators seeking to deepen their understanding of electromagnetic induction and solenoid behavior in circuits.
Angelos
Hi,
I have just started studying EM induction and I got stuck with the derivation of potential difference across a solenoid when the current in it is changing. My textbook (Physics for Scientists and Engineers by Tipler) derives it in very mathematical way just by saying that because the induced EMF in solenoid is equall to -L*dI/dt and the decrease in potential due to the resistance of the solenoid is -Ir the totel potential difference is -L*dI/dt - Ir. However I would prefere using the Lenz's Law for deriving the direction of induced EMF. So I say that because the current is in some direction it causes a decrease in potential in that direction due to the resistance. That is -Ir. But because the induced current wants to oppose the original current, the induced EMF and the potential difference due to resistance would have opposite signs. That means that the total potential difference across a solenoid would be abs(LdI/dt - Ir). Where have I made a mistake? Thanks for your help.
Angelos said:
... But because the induced current wants to oppose the original current, the induced EMF and the potential difference due to resistance would have opposite signs.
What about induced current when the current in solenoid is decreasing? Will it still oppose the original current?
I think potential difference and EMF are different terms and you must understand them clearly. What do you think about the direction of current and potential difference within an electric cell?
Well I didn't really think of the situation when the current is decreasing. In that case the induced current would be in the direction of the current. However isn't it true that when I have a circuit with a power supply, switch and a solenoid and I turn the switch on, the current starts from zero and keeps increasing until some value? Or does it first go up and then down again? But in that case we would have to use that equation I wrote for the part, where it goes up...
Yes, EMF and potential difference are different terms. I think of EMF as a part of the total potential difference. The example you wrote is a good one. The current in a battery goes from lower potential to higher potential. So it opposes the EMF and thus the total potential difference is the EMF - Ir, where r is the internal resistance.
  • · Replies 16 ·
