Potential difference across a square
2 replies · 4K views
shawli
potential difference across a "square"
Two charges are placed at the corners of a square. One charge, +4.0 μ C, is fixed to one corner and another, −6.0 μ C, is fixed to the opposite corner. What charge would need to be placed at the intersection of the diagonals of the square in order to make the potential difference zero at each of the two unoccupied corners?
V= (k*q)/ r
I tried to make an equation adding V1+V2+V3=0, but I end up having two unknowns ("d" for distance and "q" for the unknown charge at the intersection). Can someone help me set up the equation please?
show your working. I think you can just do this in one equation, the problem is symmetric.
The equation you suggested is correct, and you know one side immediately, right?
Hey , the problem is symmetric as suggested by Onamor and you know that the length of half a diagonal is 1/(2)^(0.5) times the side of the square. So in your equation all the d's will be canceled and u will be left with q as the only variable
