Potential Difference between Concentric Circles
1 reply · 8K views · last reply
codfishman
Three concentric circles of radii 1.5m, 2.5m, and 4m are filled with a gas that breaks down in electric fields greater than 1.6 x 10^7 volt/meters. What is the highest potential difference that can be maintained between the innermost circle and the outermost circle. (Hint: the middle circle must be maintained at a potential such that breakdown of the gas is about to occur on its outer surface as well as on the surface of the inner most circle).
Change in potential from A to B = [itex]\int E \cdot dl[/itex]
I calculated the net charge that the inner most circle needed to have to produce an electric field of 1.6 * 10^7 V/m at its surface. I also calculated net charge needed by the 2nd circle so that the sum of the two fields would be 1.6 * 10^7 V/m at the outer surface of the second circle (as per the hint given). However, when I then integrate the net electric field from 1.5 m to 4.0 m, I don't get the answer given in the book.
The answer given in the book is 31.1 MV for reference. The book also claims that 2nd circle must be maintained at a potential of 18.8 MV (I think relative to the outermost circle).
Problem solved. I realized that the "circles" in question were actually supposed to be cylinders (of unspecified length). In that case, the field generated by the cylinders drops off as 1/r, not 1/r^2 as I had assumed (see http://www.davidpace.com/physics/em-topics/capacitance-cylinders.htm#em6eq2 )
Thus if E = Q / (2 Pi e0 L r), let s = Q / (2 Pi e0). For the first cylinder, s1 must be equal to 2.4 * 10^7 so that on its surface the field is 1.6*10^7. Then s2 for the second cylinder is 1.6*10^7, so that above its surface the field is 1.6*10^7. Then we integrate s1 from 1.5m to 2.5m and then integrate (s1+s2) from 2.5m to 4.0m. The sum of these two integrations is 3.106*10^7 volts ~ 3.11 * 10^7 volts = 31.1 MV
