Potential Difference in particle
6 replies · 3K views
kdrobey
A particle with a charge of -1.5 µC and a mass of 3.0 x 10-6 kg is released from rest at point A and accelerates toward point B, arriving there with a speed of 50 m/s.
(a) What is the potential difference VB - VA between A and B?
v=(square root of) -2Qo(Va-Vb)/m
everything else is given in the equation, v=50m/s, Q=-1.5 x 10^-6 C, m=3 x 10^-6, but i cannot figure out how to get Va-Vb by itself. I tried squaring both sides which gave me Va2=-4Qo2(Va-Vb)2/m, but from there I'm stuck
Isn't it just algebra?
[tex]v= \sqrt{ \frac{-2Q_0 (V_a - V_b)}{m}}[/tex] (square both sides)
[tex]v^2 = \frac{-2Q_0 (V_A - V_B)}{m}[/tex](multiply/divide to move things around)
[tex]-\frac{ v^2 m}{2 Q_0}= V_A-V_B[/tex]
You might try thinking about conservation of energy (that is where the equation you give comes from anyway):
(Change in kinetic energy) = - (Change in electric potential energy)
i plugged in the numbers and got -3 x 10^-6, but that was not right.
I plugged in the numbers (Kreil's last equation in msg #2) and got something else. Try again, be careful about properly entering the numbers into your calculator.
Hint: the answer is a lot larger than 1V.
ohh, a mental error on my part. got it, thanks!
