Potential Energy (WebAssign Question)
In summary, a 4.8 g marble is launched vertically using a spring gun with an 8.0 cm compression. The marble reaches a target 27 m above its starting position. The change in gravitational potential energy during the ascent is ? J and the change in elastic potential energy of the spring is ? J. To find the spring constant, the equations for gravitational potential energy and elastic potential energy can be used. The value of "g" is typically taken as 9.8 or 10 ms-2.
queenspublic
59
A 4.8 g marble is fired vertically upward using a spring gun. The spring must be compressed 8.0 cm if the marble is to just reach a target 27 m above the marble's position on the compressed spring.
(a) What is the change in the gravitational potential energy of the marble-Earth system during the 27 m ascent?
(a) ? J
(b) What is the change in the elastic potential energy of the spring during its launch of the marble?
(b) ? J
(c) What is the spring constant of the spring?
(c) ? N/m
2. The attempt at a solution
(a)
27 - .080 = 26.92
(26.92)(9.8)(.0048) = (1/2)(.0048)v^2
v = 22.97 <<<< Isn't this the answer? But it's wrong.
(b)
(1/2)(the answer to c: ?)(.080)^2
(c)
(1/2)(.0048)(the answer to a: 22.97?)^2 + (.0048)(9.8)(.080) = (1/2)(k)(.080)^2
k = ?
a) mgh
b) 1/2*k*x^2
From a) and b) you can calculate c)
What do you state gravity as?
the gravitational potential energy equation is this:
[tex]U_g=mgh[/tex]
"U" is the energy in joules, "m" is mass in kg, "g" is the gravity value in ms-2, and "h" is the maximum height of the object in metres. the value of "g" is normally taken as 9.8 or 10ms-12.
That might clear some of the errors up. :)
1. What is potential energy?
Potential energy is the stored energy an object has due to its position or state. It is the energy that an object has the potential to convert into another form of energy, such as kinetic energy.
2. How is potential energy calculated?
Potential energy is calculated using the formula PE = mgh, where m is the mass of the object, g is the acceleration due to gravity, and h is the height or distance from a reference point where the object has energy stored.
3. What are the different types of potential energy?
There are several types of potential energy, including gravitational potential energy, elastic potential energy, chemical potential energy, and nuclear potential energy. Gravitational potential energy is the energy stored in an object due to its position in a gravitational field, while elastic potential energy is the energy stored in a stretched or compressed object. Chemical potential energy is the energy stored in chemical bonds, and nuclear potential energy is the energy stored in the nucleus of an atom.
4. How is potential energy related to kinetic energy?
Potential energy and kinetic energy are interrelated. When an object has potential energy, it has the potential to convert that energy into kinetic energy. For example, when a ball is held at a certain height, it has potential energy. When it is released, it starts to fall and gains kinetic energy as it moves faster and faster.
5. How does potential energy affect an object's motion?
Potential energy affects an object's motion by determining how it will move in a gravitational field. The higher an object is, the more potential energy it has, and the faster it will move when released. On the other hand, if an object has potential energy due to being compressed or stretched, it will move in the opposite direction when released, as it tries to return to its original shape.
