Potential inside a hollow sphere
  • Thread starter Thread starter Logarythmic
    Potential Sphere
The discussion focuses on determining the electric potential inside a hollow sphere given the potential on its surface as a function f(θ). The potential function is derived using separation of variables, leading to the form V(r, θ) = A_n r^n P_n(cos(θ)). The participants clarify that only one boundary condition is necessary, which simplifies the problem by forcing the constant B to equal zero. The orthogonality property of Legendre polynomials is crucial for calculating the coefficients A_n, and the final expression for the potential is V(r, θ) = -u_0/3 + 4u_0/3 (r/R)^2 P_2(cos(θ)).
  • Understanding of electric potential and boundary conditions in electrostatics.
  • Familiarity with Legendre polynomials and their orthogonality properties.
  • Proficiency in using separation of variables for solving partial differential equations.
  • Basic knowledge of calculus, particularly integration techniques involving trigonometric functions.
  • Study the derivation and properties of Legendre polynomials in detail.
  • Learn about the application of boundary conditions in solving electrostatic problems.
  • Explore the method of separation of variables in solving Laplace's equation.
  • Investigate the use of orthogonal functions in expanding potential functions in spherical coordinates.
Students and professionals in physics, particularly those focused on electrostatics, mathematical physics, and applied mathematics. This discussion is beneficial for anyone seeking to deepen their understanding of potential theory and boundary value problems in spherical geometries.
Logarythmic
I have a problem finding the potential inside a hollow sphere. The problem is formulated as:
"Determine the electric potential inside a hollow sphere of radius a given that the potential on its surface is f(theta)"
I have found a function V(r,theta) through separation of variables and all I have left is to apply the boundary conditions. One is given, but I guess I need another one when my function has two unknown constants. How do I find that second boundary condition?
Your radial solution will be of the form
f(r) = Ar^n + B/r^{n+1}
So, what happens when r goes to 0? What does that tell you about B?
You'll need only one boundary condition for V(r,\theta) as a result. (Although you'll have infinite constants. Use the orthogonality property of Legendre polynomials to calculate them)
So this forces B to equal zero, right? Then my potential function looks like V(r,theta) = A_n r^n P-n(cos(theta)) and I should somehow use that the integral over P_m* P_n equals zero if m is different from n, ok? I just don't know how..?
(Damn, it would be easier if I knew how to use LaTeX) ;)
Yeah
You've almost got it. Your potential function will be
V(r,\theta)= \sum_{n=0}^\infty A_n r^n P_n(\cos \theta)
and so at r=R
f(\theta)= \sum_{n=0}^\infty A_n R^n P_n(\cos \theta)
(Check out https://www.physicsforums.com/showthread.php?t=8997", or click the image to see the code)
Since the legendre polynomials are orthogonal, multiply both sides of the above equation by P_m (\cos \theta) \sin \theta (this is important. Do you see why?) and integrate (can you tell me the limits?). So, can you take it from here?
I understand why I should multiply both sides with P_m(cos theta) but not why to include sin theta. The limits should be from 0 to pi, right?
I got it now. sin(theta) is for the substitution cos(theta) = x to work out. Then I get an expression for A_m with an integral over P_m(cos theta)f(theta)sin(theta)d(theta). But then what?
Yes. Now, what about the other side of the equation? Remember that your aim is to get the value of A_n.
If you found that as an integral, then you're done! You know the solution to the potential at any point in the sphere.
But the correct answer should be
V(r,\theta) = -\frac{u_0}{3} + \frac{4u_0}{3}(\frac{r}{R})^2P_2(\cos \theta).
The given potential at R is
V(R,\theta) = u_o \cos(2\theta).
(I'm using LaTeX!)
Since you know f(\theta), evaluate the integral using the orthogonal property!
Where exactly are you stuck at? Can you post that here?
I substituted \cos \theta = x and used the orthogonal property. Then I re-substituted to get the \theta-dependence again and now my expression looks like
A_m = -\frac{1+2m}{2} a^\textit{-m} \int_{0}^{\pi} P_m(\cos \theta) u_0 cos(2\theta) sin \theta d\theta
I don't know where to go from here.
To simplify the integral on the RHS, as I've said before, you're going to need the orthogonal property . Have you tried writing \cos(2\theta) in terms of P_2(\cos \theta)? (Also, 1=P_0(\cos \theta))
Hey, I solved it! Thanks a lot! This has really helped me in my understanding of Legendre polynomials.
  • · Replies 29 ·
