Why Is the Experimental R_eq Value Higher Than Theoretical?
The experimental equivalent resistance (R_eq) value of 8.94 ohms for a parallel circuit of a 10 ohm and a 50 ohm resistor is higher than the theoretical value of 8.33 ohms. This discrepancy can be attributed to potential sources of error, including instrument inaccuracies and the tolerance levels of the resistors, which can vary by ±7%. Additional resistance from circuit wiring, typically considered negligible, may also contribute to the observed deviation in R_eq values.
  • Understanding of Ohm's Law (V = IR)
  • Familiarity with parallel resistor calculations
  • Knowledge of measurement error and instrument precision
  • Basic concepts of electrical resistance and tolerance in components
  • Research the impact of resistor tolerance on circuit performance
  • Learn about measuring instrument accuracy and error analysis
  • Explore advanced techniques for minimizing circuit resistance
  • Study the effects of temperature on resistor performance
Students in physics or electrical engineering, educators teaching circuit theory, and hobbyists experimenting with electronic components will benefit from this discussion.
Soaring Crane
On my potential vs. current graph for resistors in parallel, the slope of the regression line is 8.94 ohm (V/I = R) for a 10 ohm resistor and a 50 ohm resistor. The theoretical value of R_eq is R_eq = 1/[(1/50 ohm) + (1/10 ohm)] = 8.33 ohm. Upon comparing the two R_eq values, I was wondering why the experimental R_eq value is higher than theoretical value. What sources of error could account for this deviation? (Oh, the regression line's y-intercept value is close to 0; it is 0.004 V.)
See above.
See above.
Thanks.
Whats the error on your instruments? Whats the error on your resistors? You answer is with \pm 7%, which is pretty good if your using high school equipment.
The other wires in the circuit have a small resistance which is usually assumed to be negligible. This could account for some extra resistance. Also, the resistors are labeled 10 and 50 ohms, but could be higher or lower based on the percentage of error (bottom line on the resistor)
27K
13K
  • · Replies 21 ·
11K
