Power Dissipated by 60W Bulb in 20V Source[/B]
17 replies · 3K views
estike
What is the power dissipated by a 60 Watt (rated at 120 V) light bulb if it is connected to a 20 V power source (assume the resistance of the bulb is constant)?
If it [/B]
Hello E, welcome to PF :smile: !
You were saying ?
I don't know where to start i know that the power dissipated is in Joules but i don't know what equation to use
Power is actually measured in Watts.
You initially have a 60W bulb running on 120V. What equation relates Power, Voltage and Current?
Yes Ok but better to write it as P = I * V.
Now using that and Ohms law write a new equation relating Power, Voltage and Resistance.
if 60 = 120 * I = 0.5 A
I use this current and know that is 120V*0.5A = W right ? and W is 60 right
Yes Ok the current is 0.5A.
You actually need to calculate the resistance as well.
hum ok i understand know so if V= RI since 220 = R *0,5A = so the resistance is 110 ohms and since is constant
20 = 110*i = so I =0.182 A
So P = I*V = 0.182 A*20 = 3.6 Watts ? Am i right ?
hum ok i understand know so if V= RI since 220= R *0,5A
should be 120V.
so is 120 = R * 0.5A = 60 ohms
And then 20 = 60*I = 1/3 A
so W = 1/3A*20 V = 6,66 watts right
but the answers are 60W , 1.67 W , 20W or 120W i really don't understand then :x
i know what i did wrong it was 240 ohms i made a stupid error
W = 1/12A*20V and then it is 1,67 W
Sorry I got called away..
Ok you got to the right answer but there is an easier route that I was trying to lead you down in post #7. I think you're substituting values too soon. There is no need to work out the current in either circuit. Here is how I would do it...
P = I * V
V = I * R
Substitute to eliminate I..
P = V2/R (Aside: I memorised that one and also P = I2 * R)
Rearrange to give R...
R = V2/P
Substitute values..
= 14400/60
= 240 Ohms
For second circuit R is the same. V changes to 20V...
P = V2/R
= 202/240
= 1.7W
You can also do it without working out R...
P1 = V12/R
P2 = V22/R
P2 / P1 = V22 / V12
P2 = P1 * V22 / V12
= 60 * 202/1202
= 1.7W
