The discussion revolves around the use of Power MOSFETs as variable load resistors for impedance matching in a thermoelectric module application. Participants explore the properties needed in a Power MOSFET, including power handling and resistance variability, while also discussing circuit design considerations.
- Technical explanation
- Exploratory
- Debate/contested
- Experimental/applied
- One participant inquires about the necessary properties of a Power MOSFET for handling ~25W of power and achieving a resistance range of a couple ohms to 25 ohms.
- Several participants suggest specific MOSFET models from the BUZ and IRF series, noting their power ratings and suitability.
- There is a question about whether these MOSFETs can vary in resistance from 1 ohm to 25 ohms based on voltage control.
- Another participant explains that enhancement mode MOSFETs require a positive voltage between gate and source to minimize resistance.
- Concerns are raised about how to interpret datasheets, particularly regarding the "Drain-Source(ON) resistance" and its relevance to achieving the desired resistance range.
- Participants discuss the potential need for a series resistor to prevent the MOSFET's resistance from dropping too low.
- One participant proposes using an op-amp to drive the MOSFET gate based on the voltage across the internal resistance for automatic impedance matching.
- Another participant mentions the possibility of purchasing a dynamic load as an alternative solution.
Participants express various viewpoints on the suitability of different MOSFET models and the methods for achieving the desired resistance range. There is no consensus on a single approach or solution, and several ideas are presented for further exploration.
Participants note the importance of experimenting with bias voltages and resistor values to achieve the desired performance, indicating that the discussion involves practical circuit design considerations that may vary based on specific conditions.
