The discussion revolves around the power of inflation in relation to the standard expansion theory of the universe, particularly focusing on the differences in expansion rates and the implications of these theories on the nature of the universe. Participants explore concepts related to cosmological inflation, the speed of light, and the observable universe, addressing both theoretical and conceptual aspects.
Exploratory
Technical explanation
Conceptual clarification
Debate/contested
One participant questions how much more powerful inflation theory is compared to standard expansion theory, suggesting that inflation might exceed standard expansion significantly.
Another participant cites Brian Greene's work, indicating that the energy from the Higgs field during inflation could be vastly greater than values associated with Einstein's cosmological constant, but notes uncertainty in the exact expansion rates during inflation.
Concerns are raised about the consistency of a constant speed of light with inflation, questioning whether inflation requires speeds exceeding light and how this relates to the nature of expansion.
It is discussed that the expansion of distances in the universe does not equate to ordinary motion, and that distances can increase faster than the speed of light without violating physical laws.
Participants mention that the expansion during inflation is generally considered to be above 60 e-folds and clarify that special relativity does not conflict with the expansion of the universe.
Several questions are posed regarding the observable universe, its volume, and the relationship between galaxies, including whether they move away from a single point or expand themselves.
One participant expresses confusion over the nature of the universe's expansion and its implications for concepts like the Big Rip, seeking clarity on the actual speed of expansion.
Participants express a range of views on the relationship between inflation and standard expansion theories, with no consensus reached on the exact nature of these concepts or the implications of their differences. Multiple competing views remain regarding the speed of expansion, the nature of distances in cosmology, and the compatibility of quantum mechanics with relativity.
Participants highlight limitations in understanding the observable universe, including discrepancies in estimates of its volume and the nature of distances in cosmological terms. There are unresolved questions about the implications of inflation for the speed of light and the dynamics of galaxy movement.
#1
fat f...
how much more power had big bang in inflation theory than in standard expansion theory? (if standard expansion big bang = 1 )
i assume it was over-c because of that power
standard expansion would be 18000000 km/min
and inflation... ?
and after how much time did speed of light turn unto what is known today?
Brian Greene in THE FABRIC OF THE COSMOS, Chapter 10, says the energy and negative pressure contributed by the Higgs field studied by Guth and Tye was more than 10100
larger than the value Einstein had chosen...via a cosmological constant.
But he also says the expansion of the universe during inflation may have been 1030 or 10100 or more...so I suspect you can pick "really,really, big' or 'nobody really knows' as an answer.
As far as is known, the speed of light has always been it's current value, 'c'.
#3
fat f...
if c was always constant then how it can be consistent with inflation if everything can move only max speed of c?
wouldnt it violate inflation theory?
inflation needs a bigger speed than that of light if its ought to be a different theory than that of standard expansion
It lasted from 10−36 seconds after the Big Bang to sometime between 10−33 and 10−32 seconds. Following the inflationary period, the universe continued to expand, but at a slower rate.
ive read that singularity has something to do with this
It's important not to confuse the pattern of expanding distances with ordinary motion. In expansion, nobody gets anywhere. No traveling from here to there. No change in relative positions with one's neighbors. Expansion just means all distances increase by same percentage growth.
Geometry is dynamic, it can be approximately static and Euclidean over short distances and for short intervals of time but that is not its fundamental nature. Gen Rel. is the theory of geometry and how it changes.
Distance growth is not limited by the speed of light.
Even today, the distances to most of the galaxies we can see with a telescope are increasing faster than c. There is no law forbidding that Most of the galaxies we can see are quite far away (i.e. technically "beyond the Hubble radius") and so the distances to them must be growing faster than c. It's a consequence of the Hubble law---the pattern of expansion---or, if you like, by the definition of Hubble distance.
Mark M
527
The exact value of the expansion during inflation varies, but it's generally taken to be above 60 ##e##-folds.
Also, the expansion of the universe (including inflation) increases the distance between sufficiently dense objects that are at rest with respect to the cosmic microwave background, such as galaxies. Special relativity forbids faster-than-light transfer of information, but there is no way to use the expansion of the universe to transfer information. There is no conflict.
#6
fat f...
1 why is unobservable universe invisible(wikipedia doesn't explain this good enough)?
2 and if observable universe is over 13,75bly then there must be pictures of this area, mostly what i see are pictures concerning age of universe(hubble deep), and maybe confuse this with space distance,
but who is right regarding volume of observable universe, here its 42bly (but state that they can see up to 47 bly), in wikipedia there someone estimated at 78b ly and even a visualization of 93b ly, what's actual estimated OU?
While special relativity constrains objects in the universe from moving faster than the speed of light with respect to each other, there is no such constraint in general relativity.
3 which one is right?
and why can't quantum mechanics be compatible with relativity theories? or who is more wrong than another?
13,75*3,141= 43..
3 is it a coincidence or has it some meaning?(consider if now observable universe is 43b ly big)
4 do galaxies move from each other or do they all move away from one point(ala explosion)
-and if they move away from each other why i heard often theories that m31 and milky way will sometime collide?
5 are they in contradiction? one looks like implosion other looks like explosion
if to consider: if it imploded then shouldn't be the center be the oldest matter and the more it (as sphere) gets bigger the more newer is it at the age?
anybody can understand my way of thinking(3d logical), if i accept one thing then i see contradiction with another, are there simple english content other than wikipedia or how did you spent time understanding big bang?
6 if something expands with over lightspeed, wouldn't it contribute to big rip? and at which speed does "universe" actually expand?
7 how many km would it be from Earth to distance of 13,75b ly(just to better understand bigger distances), I've came to 13006656000000000000000km
without all these questions answered i can't continue to understand
#7
Naty1
5,605
40
Hey Fat f...lots of questions! if you study the following you'll get your answers or be able to calculate them for yourself. [One thing I forgot to post: also see nedwrightcalculator for a popular cosmological calculation tool]
Some standard dimensions...from Marcus of these forums I believe: [see below for calculation method and explanations]
The present Hubble distance is something like 13.8 Gly. The CEH is something like 16 Bly. Try dividing 13.8 by sqrt (0.73) and see what it comes to. We are working with standard model LCDM as usual with "dark energy fraction" 0.73. A galaxy with a redshift of 1.8 is at the CEH and it is currently receding with speed 1.17 or 1.2 (I'm using Jorrie's calculatorhttp://www.einsteins-theory-of-relativity-4engineers.com/cosmocalc_2010.htm with redshift z=1.8 plugged in.
The cosmic event horizon is about 16 billion LY and the so called Particle Horizon is about 46 billion LY distant. The cosmic event horizon is the distance to a galaxy which if you started for it TODAY at the speed of light you could never reach. Or if, TODAY, somebody sent you a signal, or a star blew up, we would never get the signal or see the flash, no matter how many billions of years we waited around for it.
The CEH distance is changing but only very slowly. it is approaching a limit where it will stabilize.
..Here are key excerpts from my notes [many from discussions in these forums] when I was learning this:
The… everyday notion of distance doesn't work on cosmological scales, and hence everyday intuition doesn’t work. The distance that we use in FRW cosmology is most commonly the proper distance, and if we look at the rate of change of this with 'cosmic time' (the time as measured by co-moving observers) we note that this velocity exceeds c for sufficient distance from the origin.
All this ‘superluminal’ velocity at great distances tells us is how one of many different possible definitions of distance changes. If you accept the FRW metric then you have to live with that. Other metrics that use different co-ordinates but make the same physical predictions do not contain any apparent superluminal recession.
Measuring cosmological distance [including Hubble distance] includes the issue of along "what curve" to measure length. In the usual notion of distance, one separates space-time into space and time and then measures the distance over some hypersurface of constant [fixed,instantaneous] time. [SEE the Wikipedia ‘metric distance illustration] Unfortunately, the split of space-time into space and time is in general arbitrary and depends on the choice of coordinates.
The usual notion of distance ("proper distance" measured at an instantaneous fixed and uniform cosmological time) defined in this manner (measuring the distance along a curve of constant cosmological time) does not actually measure the distance along a straight line (or the equivalent of a straight line in a curved space-time, a space-like geodesic). This is the convention used in Hubble Distance where v =HD.
A curve of constant cosmological time [along which we would like to measure a proper distance’ ] connecting two points in a FRW universe is not a "straight line", i.e. it is not a geodesic [but it is the great circle curve in the balloon analogy].
So we use a convention, an agreed upon "metric' [distance measurement] in the FLRW cosmological model.
Click on the illustrations so you can see them more clearly,,,,,note the red and brown lines and compare with the yellow 'distance'...This pictures the convention utilized.
Hubble’s law is v [actually a recession rapidity] = HD, and the Hubble sphere is defined to be the distance D at which the recession velocity exceeds the speed of light, D = c/H. HUBBLE TIME 1/H(t=now) = 13.77 byr. Light emitted from a greater distance cannot initially move closer to us. Light that superluminally receding objects emit towards us with a local velocity of c has an initial total velocity away from us due to expansion. As the radius of the Hubble sphere increases with time, some photons that were initially in a superluminally receding region later find themselves in a subluminal region; such photons can approach and eventually reach us. The objects that emitted the photons have moved to larger distances away from us and so are still receding superluminally. Thus we can ‘see’ some objects that are moving away from us faster than the speed of light. We can still see many galaxies beyond our event horizon by light they emitted many years ago
and here:
Some sample calculations via Marcus and instructions how to do them yourself:
1) Light travels at a finite speed. So, when you observe an object that is far away from you, you see what the object looks like when that light was emitted. So, when you look at Mars, you are seeing what it looked like 14 minutes ago, since that's how long it takes light to reach Earth from mars. Since the universe has a finite age, light from outside of a certain radius cannot reach us.
2). It has a radius of 46.5 billion light years. This corresponds to a diameter of 93 billion light years. It's also about 14 billion parsecs.
You may think that it should be 13.7 billion light years, but this is wrong. Remember that along with growing with time as we can see more light, the observable universe grows with the expansion of the universe. So the radius is larger.
3) Quantum mechanics is perfectly consistent with relativity. See relativistic quantum field theory.
4). All galaxies move away from each other (the space in between galaxies expands). No explosion involved. The Andromeda galaxy is so close to ours, that gravity can pull it in towards us and overcome expansion. In cosmological terms, we group all of the galaxies close to us into one 'cluster'.
No, galaxies do not expand. They are at CMB rest, so the distances in between the galaxies expands. Think of pennies taped onto an expanding balloon.
5). I can't see your image. But I can tell you that the universe has no center and no edge, like the surface of a sphere.
6). This is not really a valid question. Expansion is a local phenomena, you can only specify the rate if expansion of the distances in between galaxies, since the universe has no edge or boundary. Since the space in between galaxies is expanding, it looks like the galaxies are all moving away from us with recessional velocities. However, the galaxies actually have very little velocity. Remember, it's space that is expanding. This apparent velocity is given by Hubble's Law, V = H0D. D is the distance to the galaxy, H is Hubble's constant. So, I guess the best way to answer your question is to give you H, which is about 70 mega parsecs per second.
Naty1
5,605
40
MArkM:
What This means is that distant galaxies on average move away from each other when distances are sufficient for expansion to predominate; The further away, the faster they recede, like in the inflating balloon analogy. 'close in galaxies' move randomly
and two adjacent galaxies {like the Milky Way and Andromedia} may collide. {These don't model well in the simple inflating balloon analogy.}
#do people on galaxies which are 13bly away see "first galaxies" when they look towards milky way?#
and do they see that milky way and andromeda are moving away from each other and/or away from observer's direction (like observers on Earth see how galaxies are moving away in the distant space(like in picture))
here it looks like implosion(inside of a sphere), because dark age can be observed around the universe(in each direction)
and this looks like surface of a sphere model
is reality in between these models? then it would be like a donut model. if there is no centerpoint which serves as center of universe then it would support what i put into "# #"
was explosion(big bang) this enormous that space expands with 70mpc / s? is inflation responsible for this?
does somebody understands it trully? i follow scientifical concept to understand something and if i take away one step before another i can't precede, understanding starts from simple and gets more complicated once something is understood but i read stuff where people start from the middle and then its complicated, then i must ask things(puzzle parts) and if they don't contradict each other, i get the picture from answers
did knowledge came(to cosmologists) from observing mathematical equations which don't contradict each other and was it then applied to understanding(imagination) which then trully understood how universe works/looks like?
