Power required to make gaseous Oxygen
  • Thread starter Thread starter Notebook
    Oxygen Power
The discussion focuses on the power required to vaporize liquid oxygen (LOX) for the Blue Streak missile. The user has calculated a power requirement of 376 kW but is concerned about discrepancies between the mass flow rates of gaseous LOX and the mass entering the heat exchanger. They seek validation of their calculations and any insights into the physics involved. The user is also looking for guidance on whether they are posting in the correct forum or if there are better alternatives. Input from knowledgeable members is requested to clarify these technical issues.
Notebook
Hello, this is my first post, and I hope its in the correct forum!
As the title says, I'm interested in the power needed to vaporise LOX(liquid oxygen).
Specifically the physics involved for an old UK missile/rocket, called Blue Streak.
Some info here for that rocket.:
http://www.spaceuk.org./bstreak/bstreak.htm"
I've done some work with Mathcad, and this is what I have so far:
http://i89.photobucket.com/albums/k207/Notebook_04/Lox_tank_31-1.jpg"
I have a value of 376Kw for this, but what's worrying me is the figure for Gas_Mass_Lox, the gaseous Lox from the heat-exchanger. Its completely different from HE_Lox_Flow. that's the mass going into the heat-exchanger.
I'm not sure any of the work I've done is accurate, just following some textbooks and using the formulas.
All help appreciated.
N.
Apologies for bumping this thread, just with no replies at all, I'm worried I caught the forum at a busy time and it disapeared into the distance!
If this is the wrong part of the forum, please advise, or if anyone knows of another one I can post to.
All input appreciated.
N.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
