Power required to reverse an electropermanent magnet
  • Context: Graduate
  • Thread starter Thread starter Undacuva
    Magnet Power Reverse
The discussion focuses on calculating the power level and pulse width required to reverse the polarity of a rod or bar-shaped alnico magnet. The user seeks to send pulses of approximately 1ms duration, 2-3 times per second, through a wire coil without heating the magnet. Key resources mentioned include the hysteresis loop of alnico magnets and a paper detailing equations for pulse energies and widths. The consensus emphasizes the need for precise calculations to ensure power efficiency in the prototype design.
  • Understanding of alnico magnet properties and behavior
  • Knowledge of AC and DC power applications in electromagnetism
  • Familiarity with pulse width modulation techniques
  • Basic principles of magnetization and demagnetization processes
  • Research "hysteresis loop of alnico magnets" for insights on magnetic properties
  • Study "pulse width modulation for electromagnets" to optimize power delivery
  • Examine the paper "Electropermanent Magnets" for equations on pulse energies and widths
  • Explore "AC vs. DC in electromagnet applications" to determine the best power source
Inventors, electrical engineers, and researchers involved in magnet technology and electromagnet design, particularly those focused on power efficiency and prototype development.
Undacuva
Hi,
I need to know how to calculate the power level and pulse width required to revers the polarity of a rod or bar shaped alnico magnet, depending on the width. I also don't know whether to use AC or DC power.
I'm prototyping an invention and it needs to be as power efficient as possible.
If you don't understand if you need to use AC or DC power, then I have to question if you know enough to be making prototypes and inventing things involving magnets and electromagnets. Do you know how an electromagnet works? What would happen if you pump DC through an electromagnet? How about AC?
Unless you are asking something else related to the AC or DC part. I assume you are asking about pumping it through the coils.
power enough to heat the metal to 900 degree C plus the power to produce a magnetic field strong enough to magnetise the metal while it cools. Does not sound efficient. why not just turn it around ?
Hi Folks,
Just to avoid confusion, I need to send pulses something like 1ms duration (or shorter), maybe 2 or 3 times a second down a wire coil around an alnico magnet to reverse its polarity. This process doesn't require heating the magnet at all. Just a strong burst of electricity.
The theoretical materials I've found out there are a bit short on the details as to the power and pulse width required for the given physical size. This design is used in switchable magnets from a lot of manufacturers.
If Drakkith knows the answer but doesn't want to give it, then he doesn't have to. ... :-)
Undacuva said:
Hi,
http://www.google.co.uk/search?q=hy...HVCaGS0QWStIHgDA&ved=0CCMQsAQ&biw=942&bih=445
Hi Undacuva,
Are you asking about the –H demagnetising force? In that case the above websites provide a wealth of information on alnico magnets. Mind you I’ve not gone through all of them but mostly they are dealing with a constant reverse magnetic force field and not a pulsating one. Maybe there are some which will tell you the minimum required time needed.
Can't say I do. I just usually play intercept to a lot of the "new guys" here that ask questions that sometimes make no sense or that makes them appear like they don't know what they are doing. It seems like you know a bit more than that however. My apologies.
10K
