Power strip causing electronic damage?
The discussion centers on whether unplugging and re-plugging an electronic device from a power strip affects its lifespan compared to simply switching the power strip on and off. Participants concluded that, under normal circumstances, both actions should not significantly impact the device's longevity, as power supply circuitry typically protects against power spikes. However, it is advisable to switch off the device or unplug it from the power supply before toggling the power strip to prevent any potential electrical surges. The terminology for power strips varies by region, with terms like "power boards" in Australia and "multi-boxes" in New Zealand.
  • Understanding of basic electronics and power supply circuitry
  • Familiarity with power strips and their functionality
  • Knowledge of electrical safety practices
  • Awareness of regional terminology differences in electrical equipment
  • Research the protective features of power supply circuitry in electronic devices
  • Learn about electrical safety standards and best practices for using power strips
  • Investigate the impact of power surges on electronic devices
  • Explore regional variations in electrical terminology and their implications
Electronics enthusiasts, electrical engineers, and anyone concerned with the longevity and safety of their electronic devices when using power strips.
dmehling
This is a very basic electronics question, so I hope this is an appropriate forum.
When an electronic device is plugged into a power strip, does it make any difference to the device whether it is unplugged and re-plugged from the power strip or if the power strip is switched on or off. I have someone telling me that the life of a piece of electronic equipment is being shortened by switching the power strip on and off. They insist that I should only unplug and re-plug the power adapter of this piece of equipment. Is there a real difference with a relatively new power strip?
Greetings :smile:
Switching the power strip on and or compared to plugging and unplugging a plugpack should not make any difference in the way being suggested.
Any damage to any device plugged into the power strip via a plugpack "should" under normal circumstances be protected from power spikes by the power supply circuitry in the plugpack
That being said ... personally I would always make a habit of switching off the device or unplugging it from the plugpack before switching off the power strip or unplugging the plug pack
as an aside ... out of curiosity ... power strip ... is that a Nth American slang term ?
in Australia they are called power boards, In New Zealand ( when I lived there) we used to call them multi-boxes. Then when I moved to Australia, I had to get used to a new term :smile:
cheers
Dave
Is there something more you haven't told us? Maybe your advisor was talking about the case where there are multiple devices plugged into the one strip, and switching the strip OFF before unplugging one means all the other devices are repeatedly subjected to needless ON/OFF stresses?
I reckon you have it sussed, N.O.
If the device has its own on/off switch, if would be good practice to switch that off before unplugging it, to avoid somebody getting a surprise (or an injury) when they plug it in again!
In the UK it is quite common and legal for household power sockets to have no switch on the socket (e.g.
http://www.wickes.co.uk/MK-13A-Unswitched-Dbl-Socket-K781PPK/p/195081 from a UK nationwide chain of DIY shops), and there is no logical difference between that type of socket and plugging into a live power strip.
Yes, but apparently it isn't universal here: my girlfriend grew up 40 miles from where I grew up and calls it a strip-of-plugs. Descriptive, but sounds vaguely dirty if you say it too fast.
You're telling me nobody commonly calls them a relocatable power tap?
  • · Replies 31 ·
  • · Replies 16 ·
23K
